Fuse box replacement
Old Aug 15, 2018 | 09:24 AM
ejlane's Avatar
ejlane is infamous around these parts
Unhappy Fuse box replacement
I have a 1997 DB7 3.2 . A short occurred in the fuse box passenger side interior under removable interior panel (under pass side airbag). Can the fuse box along be replaced with standard aftermarket unit . Box melted near fuses 18 and 19.
Thanks in advance
Jim Lane
ejlane@aol.com
865-386-1216 cell
Cape Coral FL
Old Aug 15, 2018 | 09:59 PM
J doubleU's Avatar
It would be easiest to get the part number off the original and find a used one that plugs right in. JAGUAR part could be had for a reasonable price and a lot less work.
Old Aug 16, 2018 | 06:21 AM
ejlane's Avatar
Fuse box
Thanks...do you have a Jag number available? Trying to sort out from Aston in North America if the box and harness are all one and if I can insert a new box. Thanks for any tips you may have
Jim
Old Aug 16, 2018 | 06:49 AM
J doubleU's Avatar
Fuse box is removable from the harness, you will find the part number on it.
Fallon
May 19, 2013 10:29 PM
jus
Feb 15, 2011 06:18 AM
