2009 Aston Martin DBS Door Latch
Old Sep 22, 2018 | 04:42 PM
Sokalaw's Avatar
Sokalaw is infamous around these parts
Hey guys! The interior passenger-side door latch cable in my DBS has completely disconnected. I have since removed it from the door to try to reinstall it but I am unable to reattach neither the metal hook inside the door nor the plastic holder/bracket that's next to that metal hook. Does anyone have any guidance as to how to proceed? I've been able to take off the interior aspect of the door but I am not able to reach inside the door to reattach the metal hook to where it's supposed to go. Many thanks in advance.
The metal hook I am unable to reattach.
The entire passenger-side door latch, removed from the inside of the door.
Old Sep 23, 2018 | 02:38 PM
J doubleU's Avatar
You may want to get a copy or download of the service manual and proceed to remove the entire latch assembly to inspect. That cable doesn't just fall out of position, there's more to it than that.
Old Sep 23, 2018 | 04:09 PM
Sokalaw's Avatar
I was able to find DB9 and Vantage workshop manuals, and I will see if I am able to easily remove the door latch from here. Thank you for the advice!
Old Sep 23, 2018 | 07:55 PM
spyder997s's Avatar
spyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to behold
This is a fairly simple fix:
Remove the opposite, still functional door pull, note the wiring, and copy on the side that needs it.
This is the part you should remove.
The underside of the door pull has placed for each of those tabs.
ID:	529902   Click image for larger version
Old Sep 23, 2018 | 08:36 PM
J doubleU's Avatar
I believe he's on the other end of the simple inner handle to cable. The puzzle is @ the door latch side.
Old Sep 23, 2018 | 08:47 PM
Sokalaw's Avatar
Thank you for your reply, spyder997s. Unfortunately, it is on the other side of the cable by the latch, as stated by J doubleU. I will attempt the repair sometime in the upcoming week when I have time. I will of course post an update.
Global Autosports
Feb 21, 2012 01:03 AM
acabrera
Jul 2, 2011 11:24 PM
