Why would you send out the module? If the SRS light was on due to say, a seat belt tensioner fault - what's anyone gonna do with the module that will clear the fault? When you put the SRS module back the error will reappear.
Correct - CFFF is an internal module fault. The module needs replaced. However a replacement will need coded specific to your vehicle.
The module is made by Continental/Temic - it is a Volvo part. To get at it to remove the rear console.
See pic for location
Reason: added pic
