Wheel Alignment
Old Jan 7, 2019 | 08:55 PM
lovingit's Avatar
lovingit is infamous around these parts
Wheel Alignment
Do you guys get alignment at AM dealer? Or any alignment shop? My dealer says they do four wheel alignment for $300. Wasn’t sure if AM require anything special that only dealers can do.
Old Jan 7, 2019 | 09:50 PM
J doubleU's Avatar
If your tire wear is good, and it drives straight I'll save you $300. If you want a detailed alignment GMG motorsports is who I'd recommend.
Old Jan 8, 2019 | 06:01 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I had my local AM dealer do an alignment on the Evora and they could've done a better job. Some numbers were just on the edge of the range. For $350, I was expecting them to be all dead center of the range. I think they allow so much time to get it done and that's that.
Old Jan 8, 2019 | 07:30 AM
09DBS's Avatar
5 Year Member
09DBS is infamous around these parts
Got my DBS done with a partner shop I work with for $225.00. They utilized 4 wheel alignment Hunter kit and even gave me the printouts which validated some really bad tire wear issues I was encountering. The printout spec sheet is not only essential to know where I stood yet allow for some adjustability to my liking. I highly recommend this is definitely needed and do not skip on core maintenance items - after all, you are driving an Aston .
Old Jan 8, 2019 | 08:52 AM
MRCW's Avatar
I had mine done at my local dealer. $200. They check alignment every time it's in ands then let me know if it needs it
Old Jan 8, 2019 | 09:04 AM
5 Year Member
I plan to do an alignment when I put the summer wheels back on in April. It drives straight to me, but I don't know if an alignment has ever been done on my car.
Old Jan 8, 2019 | 09:52 AM
J doubleU's Avatar
If you have your car aligned it's important to have the angle sensor for the steering calibrated, so a dealer trip may be in order if done somewhere else.
Old Jan 8, 2019 | 12:03 PM
E5PR1T's Avatar
E5PR1T is infamous around these parts
The reason dealers quoted so high is because some adjustment bolts are very hard to get to & dealers usually may removed some components to get to it. I was quoted as high as $580 at a dealer.
I got my alignment done at a local shop for slightly more than alignment on regular cars. The bolts were hard to get to but not impossible. FYI the newer alignment machines have my V8 Vantage in the system along with all the OE specs & location of the adjusent bolts. (however I asked for a lot more camber in the front).
Old Jan 8, 2019 | 12:29 PM
J doubleU's Avatar
May I ask which place you used for alignment setup?
Old Jan 8, 2019 | 03:37 PM
E5PR1T's Avatar
Pit Garage in El Monte, CA. This is a race shop & they service all of my race cars.
Old Jan 8, 2019 | 05:28 PM
J doubleU's Avatar
Nice, when you said local I was thinking Eastvale.
Old Jan 8, 2019 | 07:54 PM
E5PR1T's Avatar
Are you from Inland Empire area?
Old Jan 8, 2019 | 08:20 PM
J doubleU's Avatar
Eastvale also.
Old Jan 8, 2019 | 08:31 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
I have a shop local to me that is just a block from the Aston dealer. They do my Lotus as well. There's always at least a couple of Porsches in the queue in addition to various exotics. You know you're at the right place when they ask you how much you weigh and what kind of driving you do. They're only a couple hundred dollars.
Old Jan 9, 2019 | 01:03 AM
TR-Spider's Avatar
5 Year Member
TR-Spider is infamous around these parts
I always go to a small local shop.
The first time they removed the front center lower panel, but learned from that - since then the alignment is done without panel removement.
It's not rocket science - however the mecanic must be a real good one. I always bring the torque specs along, that helps.
And if I require some non-standard adjustments, I think about in advance what alignment I want.
Then I talk to the mechanic and discuss it briefly. Usually I stay during the alignment...
Thomas
