Passenger Seat Heater
Old Mar 1, 2019 | 01:59 AM
AMTas's Avatar
AMTas is infamous around these parts
I have a 2007 Vantage and it has a buggered passenger seat heater, I am assuming the element. Can anyone assist with the manufacturer or an aftermarket one that would work, an original "Aston Martin" part was ludicrously expensive.
Old Mar 1, 2019 | 04:19 AM
TR-Spider's Avatar
5 Year Member
TR-Spider is infamous around these parts
Basically the seat heating in an 07 consists of 3 functional parts:
the rear heating wire,
the bottom heating wire and the bottom thermocouple (the thing in the center).
On the heating itself, there are 2 things which can go wrong:
Broken wire in one of the cushions (should be possible to replace with a similar type of heat wire),
broken thermocouple, which will disturb the feedback loop (probably can be replaced by a skilled electrician as well?).
Of course also the switch and fuses need to be checked.
Basically you start with a classic error analysis working your way along the flow path of the electricity...
HTH,
Thomas
Old Mar 1, 2019 | 07:43 AM
Aston502's Avatar
Aston502 is infamous around these parts
I believe these seat heaters were a recall item by Aston Martin.
Old Mar 1, 2019 | 04:06 PM
Vantagelvr's Avatar
Vantagelvr is infamous around these partsVantagelvr is infamous around these parts
There was a recall on the 07 for seat heaters that either didnt work or had a mind of their own . They added a secondary module under the seat that was supposed to fix it . My drivers side has never worked since and the pasenger side kinda sorta works . Frankly the seat heaters suck for an expensive car . The seat heaters in many other cheap cars work way better .
I gave up with mine as I really dont drive in cold weather and I certainly dont let the seat heaters spoil my driving experience .
Every time I hit the start button I get all warm n fuzzy anyway .
Old Mar 2, 2019 | 02:56 AM
TR-Spider's Avatar
5 Year Member
Well, a seat heating is usually not rocket science - it should be possible to install some reasonably priced aftemarket devices while still using the stock switch.
Old Mar 2, 2019 | 08:48 AM
Ghosty's Avatar
Ghosty is infamous around these parts
Were these issues fixed for all V8V's from 2008 on?
Old Jul 10, 2022 | 07:29 PM
mrtzmd's Avatar
mrtzmd is infamous around these parts
Sorry to resurrect an old thread but I want to know if removing the seats will throw a code? I need to replace the bottom seat cushions.
thanks
Old Jul 10, 2022 | 08:07 PM
J doubleU's Avatar
Throw a code? First thing is to disconnect the power at the battery. Negative cable as your dealing with the SRS. And you should invest in a diagnostic tool to check and clear afterwards. Foxwell is less than $200.
Old Jul 10, 2022 | 11:54 PM
TR-Spider's Avatar
5 Year Member
as said, disconnect the power at the battery. Just dont switch on ignition with the seats removed...
Old Jul 11, 2022 | 12:19 AM
mrtzmd's Avatar
Thanks. I do have one but was concerned that it was connected to the body control unit and I would need to have an AMDS.
Slider
Mar 2, 2011 06:45 PM
Joes95rx7
Cayenne 955/957
Feb 16, 2011 05:49 PM
Steve Theodore
Mar 22, 2010 07:51 PM
alevine
Garage Forum
Apr 18, 2009 02:30 PM
