db9/vantage brake caliper bolts
Old Mar 5, 2019 | 11:49 AM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
Are you supposed to replace the bolts when changing the pads?
Read online and wanted to verify, as I have never heard of this being done before.
Old Mar 5, 2019 | 01:42 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
You only need to replace the bolts if you remove the calipers (like when you replace the discs)..
Not necessary when just changing pads.
Old Mar 5, 2019 | 01:48 PM
randyb's Avatar
I always take the caliper off to replace pads, so I can clean them up. Thanks, now I got to go back and replace the bolts.
Old Mar 6, 2019 | 01:00 PM
davidm17's Avatar
5 Year Member
davidm17 is infamous around these parts
Is there something special about the caliper bolts on the Vantage? I've removed calipers on many different cars and never replaced the bolts.
Old Mar 6, 2019 | 01:33 PM
J doubleU's Avatar
Torque to yield bolts, manufacturer's specify replacement of all TTY bolts when removed. Steel bolts that stretch are being refit into aluminum threads. Safety items. Be aware of the stages of torque when fitting new ones. 30Nm then 80*
Old Mar 6, 2019 | 02:55 PM
XJRS Owner's Avatar
I re-used my bolts after removing the calipers. Been 4 years, calipers haven't fallen off yet. But I don't use my brakes that hard, so who knows what would happen under track day conditions...
Old Mar 6, 2019 | 03:16 PM
MRCW's Avatar
Interesting comment. I just reviewed by Aston Workshop manual and could not find a specific reference to this. Is this just a general reference you are making? I am aware of TTY bolt criteria but is is ususally spelled out and is ususally for high torque applications 30Nm +90 is not alot of torque When bolting into AL, the AL will yield way before the steel bolt
Old Mar 6, 2019 | 04:24 PM
J doubleU's Avatar
Straight from the shop manual, refit brake caliper and install 2 new bolts. Then a disclaimer about how it could fail if you do not. Then the torque spec. As above 30Nm and 80*.
oak
Jun 21, 2016 08:59 AM
CRGT3
Mar 27, 2011 06:03 PM
996 Vendor Classifieds
Jun 18, 2009 09:37 AM
BlackBear
Jan 25, 2008 02:32 PM
