Bad smell from exhaust
Old 03-13-2019, 03:46 AM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
guys when I drive my V8 enthusiastically I get a rotten egg smell wafting through the air when I stop and it is detectable if the wind blows the gasses towards the car.
the car has the factory standard cat's
is this smell normal? My other cars don't give of a bad egg smell
Old 03-13-2019, 07:03 AM
embdenb's Avatar
embdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to behold
Typical catalytic exhaust smell usually due to improper air fuel mixture. Has the car been modified in any way?
Old 03-13-2019, 08:09 AM
no modifications, but it also has not had the air intake removed or cleaned no codes on start up, itbis a bit heavy on fuel.
Old 03-13-2019, 08:52 AM
brightoncorgi's Avatar
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Try running some Techron on your next fill up. How old with is the air filter?
Old 03-13-2019, 09:52 AM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Hydrogen Sulfide.
-Your cats are on their way out
-The gas you're using has a high sulfur content
-You're engine is running lean or hot
Old 03-13-2019, 12:55 PM
Originally Posted by blue2000s
Hydrogen Sulfide.
air filters are new, gas is standard 95 petrol no lead ?
can I pull the cats and just remove the honey comb?
Old 03-14-2019, 08:49 AM
blue2000s's Avatar
I could be the cats. But they're expensive and are just one possible sources of the problem so I can't tell you to gut them. That's up to you. If it were me, I'd do the non-destructive things first like change gas stations, clean injectors.
Old 03-14-2019, 09:01 AM
I would love to gut them! Can I cut them open and remove all the restrictive material? What will happen with the scensors will it need a resistor or something to stop a code and possibly the motor going into slow mode?
i can even make up a pipe and remove them completely but I'm concerned with codes and software issues, your advise here will be a great help.
will I see a noticeable difffrence in engine performance with out the cats? And will it be lighter on gas?
Old 03-14-2019, 10:05 AM
embdenb's Avatar
You can gut the cats. That said the car’s exhaust will be louder and the ecu will probably throw an emission code. I believe at least one oxygen sensor is downstream from the cats.
Old 03-14-2019, 03:39 PM
DonRW2007's Avatar
DonRW2007 is an unknown quantity at this point
Options
Consider cat deletes and a tune and you shouldn’t have to worry about throwing codes.
Old 03-14-2019, 07:47 PM
Dalecannavan's Avatar
Dalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to behold
it depends on the year of the car. The later cars, 2012 on I believe, have secondary cats with no sensor and can easily be removed without a tune as the sensors are in the primary cats.
Old 03-15-2019, 12:35 AM
thank you for this what is a cat delete? Re the tune I live in SA we have no Aston Indy shops and the dealer is most unhelpful and will not offer any assistance other then normal maintenance they will not even sell us parts
in short we have no dealer support and certainly they do not entertain letting a client work or tinker on his car.
if I want to do a tune I will need to do it and I'm not sure what's involved?
Can you add any details here ?
Old 03-15-2019, 12:36 AM
thanks BC what is Techron? We don't have that product here I could look for a fuel additive if you guide me on what to look for?
Old 03-15-2019, 05:11 AM
Aston40's Avatar
Aston40 is a jewel in the roughAston40 is a jewel in the roughAston40 is a jewel in the roughAston40 is a jewel in the rough
Cut open the cat pipes remove the inside ****!
I installed the sensors again.
Get a cat delete file or just do what I do Every 4 months when the code comes up I delete the code with a OBD2 Reader.
Done. The car still look original underneath.
Old 03-16-2019, 12:47 PM
DonBond's Avatar
DonBond is a jewel in the roughDonBond is a jewel in the roughDonBond is a jewel in the rough
From which exhaust? Yours or the car's?
Quick Reply: Bad smell from exhaust
