V8 Vantage driver window & mirror moving in 2-3 inch increments
Old Jun 8, 2019 | 06:40 PM
flat_plane_eddie's Avatar
flat_plane_eddie is infamous around these parts
Need some help in case anyone here has had this issue or knows about it. Long story short, had a new battery installed in my car after it died and upon doing so, the convertible top along with the driver side window & mirror are not working properly. The driver side window and mirror are only moving in small increments. I'm assuming this is also confusing the convertible top, as a result, it's not opening.
I've disconnected the battery and played with the fuses and that hasn't helped the issue (although it did fix the memory seats which also stopped working). To make things more interesting, when I start the car, the window will go up and down fully but after that it's back to increments.
My next thought is to replace the driver's door module. Any other ideas?
Old Jun 8, 2019 | 07:53 PM
J doubleU's Avatar
Have you tried a window learn procedure?
Old Jun 8, 2019 | 08:04 PM
Forgot to mention that I've tried that numerous times. Thanks, though.
BMW-North
Sep 21, 2018 06:15 PM
mkoenigsheim
Jul 15, 2015 01:41 AM
RCH
Oct 7, 2005 10:43 PM
