Cabin Fuse box USA
Old Jun 24, 2019 | 07:57 AM
oo7's Avatar
oo7
oo7 is just really niceoo7 is just really niceoo7 is just really niceoo7 is just really nice
Cabin Fuse box USA
Can not locate cabin fuse box... Manual shows location appearing below windshield inside. Must glove box and or trim need removal to access? Yes I feel a little stupid...
Old Jun 24, 2019 | 08:26 AM
embdenb's Avatar
You don’t mean the fuse box located beneath the carpet in the passenger footwell?
Old Jun 24, 2019 | 08:28 AM
BMW-North's Avatar
BMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant future
There are three fuse panels. One under the hood toward the back side of the engine on the right side (passenger side for North American LHD). Second in the trunk (boot) and the third in the cabin passenger foot well.
The fuse panel in the cabin is actually in the passenger foot-well below the glove box - where the floor slopes and feet would rest. - you have to lift up the carpet then you will see an aluminium panel with a ton of screws - the fuse panel (also the main CEM ) is behind that panel.
I'll dig out some pics.
Edit: Added images:
CEM Location - Passenger foot well LHD & RHD
Once the aluminium cover is removed the CEM/Fuse panel is behind it - looks like the image of the one below. If you will be disconnecting/reconnecting the wiring harnesses I would strongly urge you to disconnect the battery first.
CEM removed
CEM Fuse List
Old Jun 24, 2019 | 08:41 AM
oo7's Avatar
oo7
Thanks, I will look under floor mat.
Old Jun 24, 2019 | 11:08 AM
J doubleU's Avatar
You will need a T-30 torx bit for the 7 screws on the access panel.
Old Jun 25, 2019 | 08:21 AM
oo7's Avatar
oo7
Thanks, Nothing is marked. If time is available I will test and post a pic of box with corresponding # in workshop manual.
Old Jun 25, 2019 | 09:21 AM
BMW-North's Avatar
The markings are moulded into the CEM housing - they certainly are not easy to see unless you have the CEM removed. Here is a pic showing the fuse numbers stamped onto the housing. Refer to the fuse chart I posted a couple up. Be aware this one has certain fuses missing (removed) I've borrowed for other vehicles - and the fuse slot might not be empty on your vehicle - The fuse ratings are also above however.
CEM fuse numbers
XWCGT
Nov 11, 2013 04:40 PM
keitheva
May 26, 2011 09:22 PM
jus
Feb 15, 2011 06:18 AM
jplanaux
Jan 10, 2011 01:37 AM
