AM Battery Conditioner never turns green
Old Mar 12, 2020 | 10:14 PM
MRCW's Avatar
Originally Posted by AXARUNNER
Mine turns green after 12 hours (plugged into the rear hatch area). My battery is 7 years old now.
7 years on a battery? wow. living on borrowed time!
Old Mar 13, 2020 | 05:30 AM
bobdisp's Avatar
5 Year Member
bobdisp is infamous around these parts
My original AM branded conditioner will go green after about 3 hours. Then it cycles between green and orange while it is plugged in. I use the socket in the trunk.
Old Mar 17, 2020 | 01:30 PM
kaj750's Avatar
kaj750 is infamous around these parts
How long is the cycle interval? Maybe I need to look at mine a bit longer? LOL
Old Mar 17, 2020 | 02:15 PM
sliderule01's Avatar
sliderule01 is infamous around these parts
Usually a couple of hours or so depending on the condition of the battery
Old Mar 17, 2020 | 02:17 PM
kaj750's Avatar
OH! Well, in that case, mine may be just fine. I'll just have to go and check on it a couple times. Thanks!
Old Nov 23, 2024 | 04:26 PM
Tekjansen3's Avatar
Tekjansen3
Hi did you ever figure this out? My CTEK charger is AM branded but I believe is also a 800. The orange and green lights alternate which the manual seems to suggest means its not working for a variety of possible reasons. I guess I can leave it on and see if it ever hits green solid, I assume when charging its supposed to be solid orange which mine only indicates for about the first 15 seconds after its plugged into the wall.
Using the boot port & I understand my battery is 4 years old. Battery gave me no trouble starting since I bought in early September.
Old Nov 23, 2024 | 08:30 PM
kaj750's Avatar
Mine has a series of lights, not just one. Not sure how yours works. When you first plug them in, it can sometimes take overnight for the lights to go all the way. When you start it, it goes through the charging program and shows progress of that, not the status of the battery.
leftlane
Feb 10, 2026 10:04 AM
macksamus
Dec 13, 2016 03:47 PM
C_Fooo
Oct 3, 2012 08:35 PM
CJKCyclone
Jun 9, 2012 02:51 PM
bogart101
Dec 29, 2010 09:11 AM
