07 V8V manual trans with rear steer sensation
Old Mar 24, 2020 | 04:47 PM
boxercupdave's Avatar
boxercupdave has a spectacular aura aboutboxercupdave has a spectacular aura about
When I up shift on acceleration or down shift I sometimes get the sensation of rear steer. It feels like the car is trying to steer from the back end ever so slightly.
I have the car raised and the wheels off. Previously I did a visual of the rear bushings and used a pry bar to see if they flexed and found no issues nor did I see anything wrong with the rear sub frame mounts. This time I'm taking both shocks out, so I can have the car at ride height and see if any of the joints to flex.
Anyone else experienced this?
Old Mar 24, 2020 | 05:11 PM
Denny 6.53's Avatar
Denny 6.53 is infamous around these parts
Dave,
A couple of years ago, if I hit a rough patch, me car acted like that. New Michelins cured that and drastically improved the ride quality
Old Mar 24, 2020 | 07:28 PM
JL_MPLS's Avatar
JL_MPLS is infamous around these parts
Checking the linkage makes sense. My first thought would be the toe links but if those are good, then the other thing that occurs to me is that a failing rear differential or rear axle could have the same effect, e.g. a different level of force on one wheel vs. the other would create a steering sensation as the wheel with more drive would tend to rotate the car. Just a thought.
Old Mar 24, 2020 | 07:50 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Have you had it aligned recently? If so, what's the rear toe? How smooth are you with the power transition/clutch smoothness? Do you have traction control on? What's it like with it off? How old are your tires and what type are they?
Old Mar 24, 2020 | 08:07 PM
J doubleU's Avatar
Tire condition first, and as stated have you has an alignment? Tire pressures, condition and age. All addressed pre alignment.
Old Mar 25, 2020 | 01:36 PM
The car did this with the old Continentals and also with the new Michelins with less than 500 miles on them so thinking I can eliminate tires.
Today I've taken the right rear shock off and placed the suspension at ride height and tried to move all the joints to see if any were worn and all seem good on this side. Will try the other side tomorrow.
As far as alignment I haven't check as the tires wear even and overall handling is good. I usually do my own alignments with some tools I've made up over the years but don't have them here. May setup a fixture on jack stands and use a tape measure to check toe. I'm leaning away from this as the cause as this only happens under a load.
I also wondered about the traction control acting up but to be honest never checked with it deactivated. Worth a try if no bad bushings found.
I've had bad axles in a posi diff before on my other car but never felt like this. Rotating the axles hasn't shown anything so far.
Old Mar 25, 2020 | 01:41 PM
blue2000s's Avatar
This is exactly why alignment probably is the issue. Rear toe out under squat will have the car scurrying in all directions.
Old Mar 26, 2020 | 10:43 AM
embdenb's Avatar
As far as alignment I haven't check as the tires wear even and overall handling is good. I usually do my own alignments with some tools I've made up over the years but don't have them here. May setup a fixture on jack stands and use a tape measure to check toe..
You cannot do a proper rear wheel alignment with homemade tools. The alignment is based on the wheels relationship whit the “cars” chassis. The alignment must reflect this.
Sid3ways
Cayenne 955/957
Oct 21, 2016 12:17 PM
maor
Jun 26, 2013 10:04 AM
smithk3933
Mar 13, 2010 04:58 AM
kscheible
Mar 10, 2009 12:25 PM
p0rsch3
Apr 13, 2008 10:10 AM
