2012 v8v
Old Sep 16, 2020 | 08:26 AM
teddy_lee2000's Avatar
teddy_lee2000 is infamous around these parts
2012 v8v
This is an odd one...
I can't seem to get the time right on the analog clock. The 2012 is not like the older models with the holes where you can manually change it. I can however change the time from the screen but the analog clock always sets 7-8 minutes ahead of the GPS clock on the screen. Anyone seen this before??
Old Sep 16, 2020 | 09:11 PM
007JB's Avatar
007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light
My car is 2013, same issue. Dealer fixed it few times when I was taking in for warranty work, but it's same again now. I don't know way to correct it.
Old Sep 16, 2020 | 09:21 PM
J doubleU's Avatar
Disconnect your negative battery cable for 30 seconds, then reconnect. AKA hard reset.
Old Sep 17, 2020 | 11:32 AM
Bones 53's Avatar
5 Year Member
Bones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud of
Same happened to me...hard reset was the solution.
Thanks,
JH
Old Sep 17, 2020 | 01:09 PM
007JB's Avatar
would hard reset cause any other issues like window memory or other modules?
Old Sep 17, 2020 | 01:13 PM
J doubleU's Avatar
Depends on what year, 2012. Nothing to worry about everything stays.
Old Sep 17, 2020 | 01:52 PM
Just did it, clock reset to correct time! Everything else looks good. I had to start my car for the windows to close all the way up though FYI, so don't freak out that it didn't roll all the way up at first.
Albertof1
Midwest
Aug 20, 2012 04:16 PM
FrankP
Jun 21, 2011 08:42 PM
