Buying Your First Vantage Checklist Pt 1
Hey guys, I thought I might share some consolidated knowledge that may be helpful for someone looking to purchase their Vantage.
As some of you may know, I recently purchased my 2013 V8V and I wanted to share some insight that may help others when buying their first Vantage.
Like many, I have lurked around the forums and researched intensely on what to look for when purchasing my perfect Aston. There is so much good information out there from nice folks like those on this forum, that I was able to compile a lot of what to look for when buying.
If anyone wants the excel form checklist, shoot me a PM and I'll email it. I usually use this checklist when inspecting any cars before purchase, but I added those specifics for Aston in bold on what to look out for. Below are the screenshots.
Part 2 will be years of data I collected on the Vantage to predict the depreciation. This was helpful when negotiating and allowed me to figure out which year was best for me and when I could actually pick one up. It could also be used if you want to sell your car. It was off by 1K or so for my purchase
Sources: Piston Head Forums; 6 Speed Forum; Redpantslol Youtube Videos; Definitive Buyers Guide - Aston Martin; Various other google searches.
That is a great list - thank for putting that together.
Some other things that might be added:
Exterior
-Tire date codes - plan to replace anything more than 4-5 years old.
-Center mount brake light function.
-Timing cover leaks.
-Torn driveshaft boots.
Test drive
-Check for all trouble lights on at startup (CEL, ABS, etc - make sure nothing has been hidden).
-Check for temperature gauge reaching mid-range
matt
Exterior
Test drive
matt
Exterior
Test drive
matt
Exterior
Test drive
matt
Matt, thank you for your inputs. I have updated the spreadsheet accordingly.
I have bolded:
- Center mount brake light function.
-Check for temperature gauge reaching mid-range ==> (I added that it should be 1/4 when warming up and 1/2 when operating)
I left the others unbolded as those pertain to any vehicle.
Thank Matt!
Glad to see that you are back....or somewhat back. Hope everything is going well with your house and other personal matter.
Emailed. Updated the checklist to include some roadster specific checks. I'll try to upload part 2 once I finish normalizing the data, hopefully, that will help set your price point.
before you buy... add obtain build sheet
key should be "sapphire" , "valet" also hard key and plastic second fob
check "premium audio" on stereo start up
check if fuse 22 or 15 is pulled
Included Build Sheet under Before you Buy
Fixed spelling and updated 2nd Key Fob to state plastic.
Included Premium Audio in parentheses next to Radio under interior
Included Fuse 22 and 15 under interior in bold for Aston specific
Very easy to see if the car is on a lift also pretty expensive to fix. I think around 5K. My Vantage leaked when idle over a couple of weeks. Weeps at worst when a daily driver. That would be pretty high on my check list if buying a Vantage along with surface corrosion. Not so easy to see looking over the car, but impossible to forget once discovered.
I sure do and I have updated it from what other owners have inputted. Shoot me your email to drewhwang@gmail.com and ill send it over tomorrow night. Best of Luck!
Andrew
Andrew
