Thermostat housing seal V8V
Old Oct 24, 2020 | 04:34 PM
Julioz32's Avatar
Julioz32 is infamous around these parts
Hi, can someone confirm if the jaguar thermostat housing seal, part number AJ8 003525 SEAL fit?
thanks,
Old Oct 25, 2020 | 08:31 AM
61mga's Avatar
61mga is infamous around these parts
thanks,
a year ago when i had to replace the faulty and original thermostat on my 2007 vantage, i bought the AM thermostat housing seal too (it was about $28.00(!) online from astonbits or maybe ebay, i don't remember where...), thinking it would need replacing. but when i got to the point of fitting the seal, it didn't look like the right part for the job in that it was shaped not like a seal but like a rubber rim or big, stiff rubber band that was too narrow. i didn't chance using it. it's possible that i didn't know what i was doing (very possible), but whatever it was and for whatever the reason, it was not needed, as everything worked out alright without its use. that's about all i can say. here's a pic of what i bought. it's the rubber ring on the right:
https://images.squarespace-cdn.com/c...G?format=1000w
Old Oct 26, 2020 | 04:29 PM
Vantagelvr's Avatar
Vantagelvr is infamous around these partsVantagelvr is infamous around these parts
There was a thread on here a while back about T’stat replacement and it had all the alternate part numbers for Ford T’stats and the Jag O rings I think .
Old Oct 27, 2020 | 10:49 PM
Jano4's Avatar
Jano4 has a spectacular aura aboutJano4 has a spectacular aura aboutJano4 has a spectacular aura about
Motorcraft (Ford) thermostat housing seal will work just fine. Part number RTS1079. Yes there are Jaguar versions that also fit and the one you listed appears to be correct.
StealthAWD
Sep 4, 2007 11:11 AM
schicago
Aug 17, 2006 04:16 PM
03LX470
May 11, 2006 02:09 AM
