DB9 drop link replacement / Donor part?
Old Jan 2, 2021 | 02:10 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
I searched here and the other forum and didn't see the answer...
Anyone know what brand/car this front stabilizer drop link was sourced from?
https://www.scuderiacarparts.com/par...-frt-stab.html
Mine are rusty, but still working. Be nice to replace them, but not a requirement.
Thanks,
Larry
Old Jan 2, 2021 | 02:57 PM
J doubleU's Avatar
So your saying they still have inner beauty? I don't know if you could find a solution any cheaper than the OEM ones. I'd say later model Mustang rears are fairly small and the aftermarket has adjustable ones with heim joints. They definitely resemble Ford ends and materials.
Old Jan 3, 2021 | 05:26 AM
8Tech's Avatar
5 Year Member
8Tech is infamous around these parts
If its only the rust bothering you, then at that price you should just replace them with OEM because with the time involved removing them, cleaning them up, painting them and refitting them, its simply not worth worrying about. If I was going to go to all that effort, then I would replace with rose jointed, adjustable ones simply because they are better, and whether or not I could ever tell the difference in driving, I would know that my time and effort were not wasted on a tiny cosmetic niggle, never seen unless you are under the car.
Old Jan 3, 2021 | 06:22 AM
AM4884's Avatar
5 Year Member
Thanks for the tips. I'll take a tour through the Jag/Ford parts collections and see what I find. $90 for a set of links delivered is a bit much just to replace them...
Wildcat1212
Nov 11, 2025 10:44 AM
gtmule
May 6, 2021 07:42 PM
André CHARLES
May 5, 2019 12:59 AM
speedracer800
Apr 12, 2016 07:05 AM
d-dot
Jun 8, 2011 11:33 AM
