Car Sitting - Oil Change last March
Old Jan 11, 2021 | 04:52 PM
sliderule01's Avatar
sliderule01 is infamous around these parts
Hi all:
2007 DB9 Volante. Last March I changed all the coils, plugs, fluids and did all the stuff that the DPO put off. Due to the pandemic, I only drove it about 1000 miles for the whole year (maybe 1200). I have the car on a trickle charger, and I am itching to drive the car when it gets warmer. Since the car has had so few miles put on it in a year, is the oil change necessary? I know the manual says 10K miles or yearly. I also have some minor weather stripping that needs to be replaced (bloody expensive at $265 each from Scuderia for a piece of rubber 12" long"). I will probably do the oil change and the weather stripping replacement - I was just wondering if necessary.
Old Jan 11, 2021 | 06:13 PM
ccfulton's Avatar
ccfulton is infamous around these parts
You will get multiple points of view I'm sure but for my own cars I change the oil on 5k mile intervals regardless of time. In my case, that generally works out to a year of use, give or take, but if it is longer I tend not to worry about it.
More important I think is how you drive the car. If when you get it out it gets a good long run and the oil is fully up to temperature to cook off any condensation then I wouldn't worry about the time as much. But if that 1000 miles was added 10 miles at a time to the grocery store and back, then I would be inclined to change more frequently.
Old Jan 11, 2021 | 06:26 PM
Ozzir's Avatar
Ozzir is infamous around these parts
I change mine annually but if its synthetic its fine to extend it. It will have hardly broken down at all.
Old Jan 15, 2021 | 11:59 AM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Bamford Rose has a couple videos about this topic. Mike is the big brain when it comes to AM.
Old Jan 17, 2021 | 08:03 PM
skeena river rove's Avatar
skeena river rove is infamous around these parts
If you do low miles. Every other year is ok.
Old Jan 17, 2021 | 09:01 PM
I would normally change annually per the schedule. But I have driven so few miles this year because of the pandemic, it is only maybe 800 miles since the oil change. Seems kind of a waste to do it so early.
Old Jan 18, 2021 | 06:30 AM
embdenb's Avatar
Agreed. I could be wrong, but I believe Oil manufacturers do not recommend oil changes every year, car companies do. If the car is out of warranty and you put 3 to 4 thousand miles per year the every two years is acceptable lMHO
Old Jan 21, 2021 | 02:45 PM
deckman's Avatar
I'd do it every other year if you keep that usage up. I don't know if this works with the DB9 or any sportshift, but if you have a manual I'd mash the throttle to the floor when starting it for the first time. That prevents the engine from getting a spark and just turns it over slowly, while getting the oil moving to parts that are pretty darn dry by now
Old Jan 21, 2021 | 03:02 PM
Absolutely doing the Ford "prevent the engine from turning over thing" whenever I drive it. It has been 3 months since it has been started and I am looking forward to some warmer weather to get the car on the road. BTW, the foot to the floor and crank also works on wife's 2002 T-Bird. Both cars have an identical wheelbase to 0.1". Mechanic who inspects both cars indicates they are remarkably similar underneath in terms of chassis and configuration.
Old Jan 23, 2021 | 12:58 PM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
Here is an idea which I did for mine. Many threads on forums talk about when to change the oil and how often. Answers from experts vary wildly.
As we all know its about $60 for oil at Walmart for our cars. Its the filters that is the pain for an oil change. Most of us don't drive them 10k miles a year. So regardless of how many miles I drove mine I would once per six months change the oil. ie... drain the oil from the pan, and refill the pan with new oil. Only once per year I would do the filter. In our daily cars we drive how much with one filter - 10-15k miles a year and those motors work just fine if not perfect for 100k plus miles. So not changing the filter doesn't hurt a darn thing. Honestly changing the oil that often was probably a waste also. But for $60 and 10 min of time why not. I would choose to do that when I had it on the lift for cleaning.
OP - I wouldn't change the filter at all. Just if its easy change out the oil. Peace of mind for you.
My 2 cents. Hope everyone is doing well on here. I am in Afghanistan for now and a really really good friend bought my DB9 last summer and loves it. IF I come back I will probably grab another AM but this time it will be straight piped. No more quiet AMs for me.
ScottDy
Feb 4, 2021 08:48 AM
Ylincooper
Cayenne 958
Apr 29, 2012 09:33 AM
JayBellmo
Oct 6, 2010 07:22 PM
drkside
Dec 23, 2009 12:31 AM
mass
May 26, 2007 10:55 AM
