Recommendations on where to buy Glass Interior Buttons
SubscribeThe problem is those switch are not meant to be taking apart, usually you have to break them apart.
There is, as I recall, an older thread regarding the differences between DB9, DBS, and Vantage glass switches and that they are not universally compatible because of the plug pattern at the back. Definitely worth researching before plunking down on a switch that doesn't work or plug into the wiring harness...
Quote:
https://www.ebay.com/itm/14401335024...d542%7Ciid%3A1
Did you see see that pile of bolts? All from a 17 V8 Vantage supposedly. $150 or so USD. I wonder what shipping would be? Never mind, looked and it's about $180 to shipOriginally Posted by j66
here is another one for you
