Building My DB9 to GT3 Spec!!
Old Jul 6, 2021 | 07:24 AM
XJRS Owner's Avatar
Originally Posted by Bones 53
With regard to the one of the above graphs...the simplified relationship between HP and Torque ...HP=(TxRPM)/5252....I would be suspect of the data when the curves don't cross at 5252RPM.
Thanks,
JH
Different hp and torque scales is the reason.
Old Jul 6, 2021 | 09:04 AM
Bones 53's Avatar
5 Year Member
Bones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud of
Looking at the first graph from Phil57DBS.
Thanks,
JH
Old Jul 7, 2021 | 06:39 AM
Phil57DBS's Avatar
5 Year Member
Phil57DBS is infamous around these parts
Hello
Between a DB9 and a DBS with the ZF6HP automatic gearbox, the gear ratios are the strictly the same, only the final ratio changes, 9% shorter on the DBS (3.46 vs 3.154 on DB9).
For the DB9, this goes well with its more torquey engine, so the DBS compensates for its lack of torque with 9% shorter final ratio !
These short DBS intake manifolds are, however, perfectly suited to the manual DBS gearbox, which have the final gear ratio still 12% shorter!
Final drive in gear 6 for DB9 with ZF6HP = 400km/h à 6750rpm
Final drive in 6 for DBS with ZF6HP = 365km/h à 6750rpm
Final drive in 6 for DBS with Graziano manual gear box = 311km/h à 6750rpm !
with an automatic gearbox, I advise to keep long DB9 intake manifolds...
Old Jul 7, 2021 | 11:13 AM
V12Stealth's Avatar
5 Year Member
V12Stealth
So is a stock 2009 DB9 faster than a 2009 DBS? 0-60, quarter mile etc..?
Old Jul 7, 2021 | 05:44 PM
XJRS Owner's Avatar
No for both cases.
Old Jul 7, 2021 | 06:00 PM
V12Stealth's Avatar
5 Year Member
V12Stealth
Originally Posted by XJRS Owner
No for both cases.
Do you have numbers? I can't seem to find anything that looks legit. Some websites show the DB9 as faster than the DBS (12.6s vs 12.9s quarter).
Old Jul 7, 2021 | 06:09 PM
Irish07@VelocityAP's Avatar
I used to have material, not anymore.. base model DB9 with manual trans is faster than the DBS in any configuration. Even if they shared the same powertrain/driveline, the DBS was heavier in it's delivered trim.
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Jul 3, 2025 | 01:32 PM
CMCFIRM's Avatar
5 Year Member
CMCFIRM is infamous around these parts
Great thread! I too have the same idea, remaking my 05 DB9 to GT1/GT3 spec.
I have the DBR9/DBRS9 Prodrive body panels that are being 3d scanned for my daily driver/restomod. I want to 3d print my hybrid version with more modern DBS features instead of DB9 features
user 589724024824
Jul 4, 2021 10:43 AM
drivergmx
May 18, 2016 11:27 AM
GT650-25
Apr 16, 2015 06:52 PM
Mike bamford rose
Oct 22, 2014 06:07 AM
chrisfc923
Maserati
Aug 24, 2009 10:16 PM
