DB9 Front Engine Timing Cover Leak
Old Aug 2, 2021 | 08:49 PM
mjanis's Avatar
5 Year Member
mjanis is infamous around these parts
Comments: engine timing cover leaking engine oil, removal of cover to clean and renew gaskets and reseal to engine.
This was noted during my annual service. Is this common, expected?
Is this a big job? I am assuming it requires a lot of disassembly to get that cover off.
was a bit surprised at the quote to remedy.
Is this something you would trust an independent to do or would you use the local dealer?
I am in Southern California, South Orange County.
Old Aug 2, 2021 | 09:14 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
It looks to me that you have a weep, not a leak. There's no danger to the car with a weep as the oil level won't significantly change with this. Does it EVER leave drips on the floor? I wouldn't address anything this minor, not worth the thousands.
Old Aug 2, 2021 | 10:02 PM
mjanis's Avatar
5 Year Member
I agree at this stage it is more of a weep. No oil ever on floor. It is blowing oil from driving along the underside. But not a lot. It is a low mileage car, only 15k miles.
Old Aug 3, 2021 | 07:16 AM
XJRS Owner's Avatar
Common problem. Big job. Some say it is engine out while others say it can be done with the engine in place. Either way, it is mucho bucks. Don’t bother unless you have oil everywhere.
jr_spyder
Nov 30, 2022 06:07 PM
bobdisp
May 30, 2021 06:46 AM
slkret123
May 24, 2021 12:29 PM
