Rubber pedals to aluminium pedals - DB7 Vantage
Old Dec 2, 2021 | 01:55 PM
pld118's Avatar
pld118 is infamous around these parts
Can the rubber pedals be changed for aluminium pedals and is it a straight pedal pad swap or the fuller pedal?
If it’s fairly straightforward, where do you source metal pedal pads - can’t find them on my internet searches so far?
Old Dec 2, 2021 | 05:29 PM
XJRS Owner's Avatar
Yes, it is an easy swap. They probably can only be found on eBay or at parts suppliers like AstonMartinBits. They came as a packaged kit from Aston (probably made in China). You are right, however, they are hard to find.
Old Dec 3, 2021 | 10:04 AM
pld118's Avatar
Thanks, an advert for aluminium pedal pads says:
“FOR DB7 VANTAGE - PLEASE CHECK TO MAKE SURE THESE WILL FIT AS THE EARLY MODELS HAD RUBBER PADS FITTED, AND THERE MAY NOT BE HOLES ON THE PEDAL TO FIT”
Is there a way of checking by model year, mine was registered in June 2002 and has rubber pads currently?
Old Dec 3, 2021 | 10:27 AM
XJRS Owner's Avatar
Don’t know. But I’m sure you could drill any needed holes to mount the metal pads
Old Dec 3, 2021 | 06:39 PM
Chasp's Avatar
5 Year Member
Chasp is infamous around these parts
I bought an AM kit years ago for my 2001. You will have to drill holes into the metal brake pedal plate after you remove the rubber pad so as to secure the new metal pedal. I can’t remember how many holes, but the kit will supply you with everything you need including the allen head screws. I think you will have to do the same on the gas pedal. This is all from memory and that was many moons ago. It’s a small space to work and I used a punch to get the drill bit started. Also, tape the medal pedal in place before you use the punch.
Old Dec 6, 2021 | 02:15 PM
pld118's Avatar
Thanks… sound like hassle to be drilling holes in metal pedals that will sit underneath…
AstonMartin bits says they can only supply an aluminium accelerator pedal pad and not the brake pedal or footrest…
Old Dec 6, 2021 | 02:36 PM
Chasp's Avatar
5 Year Member
Could try this place for the pedals - https://www.scuderiacarparts.com/par...aluminium.html
Old Dec 21, 2021 | 11:09 PM
pld118's Avatar
Have the car now and it's great... As mentioned, it has rubber pedal pads (that's as it came from the factory)… before leaving the selling garage (an AM Heritage garage) they’d responded to my earlier enquiry and had sourced a full set of brand new (quite hard to come by) genuine aluminium pedal and foot rest pads direct from Aston Martin… couldn’t resist… the best bit though is that they thought the existing metal on the pedals would need to be drilled to accommodate the new aluminium pedal pads... They don't on mine! The existing metal pedals already have holes that are perfectly aligned to the manufactured holes on the new aluminium pedal pads :thumbsup:
[img:700:525]https://www.fullfatrr.com/gallery/albums/userpics/13261/normal_AE39DE83-7174-40F6-A38E-C2A3451111FD.jpeg[/img]
Old Dec 21, 2021 | 11:10 PM
pld118's Avatar
Have the car now and it's great... As mentioned, it has rubber pedal pads (that's as it came from the factory)… before leaving the selling garage (an AM Heritage garage) they’d responded to my earlier enquiry and had sourced a full set of brand new (quite hard to come by) genuine aluminium pedal and foot rest pads direct from Aston Martin… couldn’t resist… the best bit though is that they thought the existing metal on the pedalswould need to be drilled to accommodate the new aluminium pedal pads... They don't on mine! The existing metal pedals already have holes that are perfectly aligned to the manufactured holes on the new aluminium pedal pads :thumbsup:
https://www.fullfatrr.com/gallery/al...3451111FD.jpeg
Old Dec 25, 2021 | 11:22 AM
pld118's Avatar
Fitted the foot rest and brake pedal pads today. Not as easy as thought despite the holes being pre-drilled into the original pedal pads base. A cramped space to work in. 2 out of 3 done though so not too bad…
No idea how to remove the existing plastic/ rubber accelerator pad and then refit the new aluminium pad.
Old Dec 25, 2021 | 07:09 PM
Chasp's Avatar
5 Year Member
IIRC the rubber accelerator pad pulls off, it make take some force but it does come off. Then plan on spending more time in that cramped space attaching the pedal.
Old Dec 25, 2021 | 11:16 PM
pld118's Avatar
Thanks for the reply. The foot rest and brake pedal were rubber pads and pulled off easily. The accelerator pad feel more like a hard plastic… and does feel as though it will pull off…
Old Jan 3, 2022 | 07:07 AM
pld118's Avatar
All done now.
Foot rest pad and brake pedal pad - the original black metal foot rest and also the brake pedal were both covered by AM rubber pads. On removing the rubber pads (both just pulled off) I found that both original black pedal pads had pre-drilled holes in them. The new AM aluminium pedals also had pre-drilled holes perfectly aligned and easily screwed/ bolted on - note of caution though, the tool required is a hex/ Allen key and not a torx key (the fitment is so small at 2.5mm / 3mm depending on your eyesight it’s easy to mistake the torx for the hex. I did at first!
Accelerator pedal - the original pedal pad is made of a hard black plastic and clips on to a hook shaped piece of metal at the end of the accelerator arm. The plastic pedal unclips very easily but you can’t then screw/ fit the aluminium accelerator pad on to the accelerator arm because there’s nothing there to screw/ bolt it on to. You have to unclip the original plastic pedal and then align the aluminium AM pedal over the top of the plastic pad before pilot drilling 3 holes into the plastic pedal. You then screw/ bolt the aluminium pedal pad on to the plastic pedal. You then clip the plastic part of the accelerator pad (complete with covering aluminium pedal pad) back on to the hook on the accelerator arm and job done 👍
Old Jan 3, 2022 | 01:18 PM
UNDRPSI's Avatar
UNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond repute
Glad that you got them on, and thanks for sharing so others can learn from your experience.
Old Oct 14, 2022 | 07:58 AM
AstonDB7er's Avatar
AstonDB7er is infamous around these parts
Just a quick question... is the accelerator pedal the same as the footrest on an auto?
