V8 Vantage Spark Plugs
I thought that jaguar had and equivalent plug but it's a "5N" and not a 7N part number, I must be confused. I think I'll go with alternatives but even Rock auto does not stock that equivalent plug listed above but I did find them on Ebay.
just my l luck 😪
just my l luck 😪
was just perusing and ran across this...
No not really any difference, my old plug were still really nice but with the car going on 80k km I thought it was a good thing to change them and maybe it will help gas millage a bit. lol
plugs last a whole lot longer what with modern computer regulated fuel injection and all... however, they will ablate and as a consequence the gap will increase. as an example, i recently installed some new plugs on a 2001 ram pickup i've owned since new. i'd never changed the plugs and the tips had ablated to the point the the gap was about haff again as wide as it should have been. the truck had about 70-80,000 miles on it.
I've always used Champion plugs in my cars (including my e39 M5) because they've always been great product for the price. My car is closing in on 50k miles, and I figured it would be a good time to change them, so I ordered a set of Champion iridium 9801 plugs (RC8WYPB3) from Amazon a couple weeks ago. RockAuto has them for just under $6 each, but Amazon has sets of 4 for $10.
I haven't checked the gap and installed them yet, that's my job for this weekend.
They're listed on Rockauto, sparkplugs.com, and Summit as compatible with the 4.7L Vantage. I checked the specs for both on various websites. Both are 14mm x 1.25 thread with 19mm reach, iridium middle electrode, platinum ground, similar RIF damping, and gasket seat.
The only difference is spark position (how far the gap between the electrodes extends from the plug body into the combustion chamber). The OEM NGK plugs have a 3.5mm projection while the Champions have 3.0mm. The half millimeter is negligible, I think, in a modern engine (3mm and 3.5mm are both considered projected-tip plugs), but I guess I'll find out when I install them and dyno the car.
Just my thoughts
I'll let you know after I install them. I plan to take the car down to Jacksonville for dyno runs, but scheduling takes a while. The place I go to is usually booked 3 weeks in advance. And I'm not going to schedule that until I have the plugs in and perform a butt dyno first.
