Rapid S multiple warning lights
Old Feb 10, 2022 | 05:24 PM
Rooz1359's Avatar
Rooz1359 is infamous around these parts
Hi fellow members,
I own a 2015 Aston Martin Rapid S with only 11,000 km on the odometer. Last night when I was driving home I noticed all of a sudden multiple warning lights came on simultaneously. The temperature gauge red light came on and the gauge was at the highest, also tire pressure warning came on at the same time. At the beginning the computer wasn't reading the back tires but after couple of minutes it read the and they were fine however the yellow low pressure warning was still on. I parked the car and the next day I started the car however as soon as I started both warnings came back right away. I think I have some electrical issue. It was raining when I encountered the issues. I did disconnect the negative battery for 30 min and as soon as I connected it same warnings came on again. What is wrong with the car do you think?
Old Feb 11, 2022 | 10:12 AM
J doubleU's Avatar
Tire pressure sensor battery life is about 8 years. Your most likely due for a 4 sensors. Have you checked if tire pressure is correct with a gauge? Temp gauge full hot. Have you made sure cooling fans are running and fluid level correct? If it does it when cool your looking at an electrical issue most likely.
Old Feb 12, 2022 | 03:01 PM
Rooz1359's Avatar
Thank you for your feedback. I also think it is the electrical problem.I have tried to disconnect the negative battery, after 30 min I connected it and and I hear the fan going on and off every 2 second. Once I started the car right away the same warnings along side the low engine oil came on. There was also a big white smoke came out of the exhaust. I have booked to take the car in to AM to fix. Am I fine to drive the car? It is 25 miles away
MadeInPorshe
Jul 24, 2012 06:24 PM
vbzatty
Sep 2, 2009 01:20 AM
LamboTT
Jan 10, 2009 06:18 PM
JAY-PESOS
Jun 4, 2008 10:07 PM
