2007 DB9 Volante Top
Old Apr 7, 2022 | 11:19 AM
sliderule01's Avatar
sliderule01 is infamous around these parts
Is the convertible top hydraulically operated? I am trying to find out where my leak is coming from. It appears to the be on the right side of the car. It is fairly serious leak. However, it is only intermittent. The size of the leak is enough that I would noticed it if it were engine oil. I have not been able to see it in oil consumption.
Scott
Old Apr 7, 2022 | 01:09 PM
J doubleU's Avatar
Reservoir is fairly small and obviously it only leaks when being used. Damaged hose most likely. Hoses are not sold separately. Entire pump lines and arms. There's a place in Florida sells repair fittings to splice damaged hoses. Or if you remove yours and send it in they can replicate it. Cabriolet hydraulics.
slkret123
May 24, 2021 12:29 PM
cuddapah
Feb 27, 2020 01:56 PM
zzzamdb9
Oct 19, 2019 10:04 PM
Chris P
Apr 17, 2018 01:27 PM
randyb
Jun 29, 2016 05:36 PM
