V8 Vantage FUSE 22
Old Apr 8, 2022 | 07:23 PM
msark's Avatar
msark is infamous around these parts
V8 Vantage FUSE 22
The new to me V8 Vantage came 2 weeks ago. I've been going through it and noticed that Fuse 22 was already removed. Prior owner didn't know what I was talking about and she had it for 11 years. I'm guessing that it was the owner prior (original owner) that removed it. At this point should I just leave it as-is or put it back and see if the valves cycle? Biggest concern is they the valves have partial operation and then get stuck. I have no idea about access to pre-lubricate them but I will if I can access them.
Thoughts??
Old Apr 8, 2022 | 07:42 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
Well the noise will be beautiful..congrats on your new toy..let us know how it goes..
Old Apr 8, 2022 | 09:18 PM
J doubleU's Avatar
Install the fuse and see if you notice a difference. When installed make sure the vacuum pump doesn't continue to run as that will kill the pump due to a vacuum leak. Or you can........best advice, leave #22 out and don't worry about anything.
Old Apr 8, 2022 | 10:42 PM
61mga's Avatar
61mga is infamous around these parts
i took f22 out for a day trip once then put it back in. i like to be able to open it up with the throttle pedal.
PJK
Apr 12, 2021 08:38 AM
Gene G
Mar 13, 2016 09:58 PM
captain Greg
Sep 12, 2013 05:14 PM
Dr. G
Apr 28, 2012 02:57 PM
jus
Feb 15, 2011 06:18 AM
