‘07 Vantage V8 - Intermittent Start up problem
Old Jun 27, 2022 | 08:01 PM
JKhlok's Avatar
JKhlok is infamous around these parts
Hello all,
I’ve owned my ‘07 Vantage V8 w/ about 35k miles for about 2-3 months and there’s an issue that I’ve been having ever since I got the car.
Upon cold start, the car fires right up with no issues. If you shut it off and start it within about 5-10 minutes, it will also start up but not as quickly. If the car sits somewhere between 20 mins - 3 hours, it takes a while to start it up but it eventually starts and it struggles for a bit but then idles fine.
Usually after this happens I smell fuel.
Has anyone else experienced this? Trying to figure out what it could be.
Old Jun 27, 2022 | 08:38 PM
J doubleU's Avatar
Definitely over fueling on warm or hot start. #1 thing is a leaking injector or injectors. Have the spark plugs removed to check condition. You can try an alternative injector cleaner in your fuel tank but it may take awhile to see results.
Old Jun 27, 2022 | 08:47 PM
JKhlok's Avatar
I greatly appreciate your feedback.
When I first got the car, I gathered all of the maintenance records so I could see what’s been done and what’s left to do based off the recommended maintenance schedule.
I haven’t gotten a chance to check the spark plugs yet but I did buy a set of OEM Aston plugs that I haven’t gotten a chance to install yet.
I also have a new PCV valve, thermostat, engine air filter, cabin air filters, and oil change kit
Old Jun 27, 2022 | 08:58 PM
J doubleU's Avatar
Sounds like you are on your way to get things done. Make sure you read the spark plugs upon removing. Meaning excessive fouled ones. It only takes 1 out of all 8 to have issues that your describing.
-JW
Old Jun 27, 2022 | 09:02 PM
JKhlok's Avatar
-JW
I greatly appreciate all of your help!!
random question, do you have FB?
Old Jun 27, 2022 | 09:23 PM
J doubleU's Avatar
Absolutely not.
Old Jun 27, 2022 | 09:34 PM
JKhlok's Avatar
Absolutely not.
that’s fair! I will look into the things that you recommended and keep you updated.
I love the car, just embarrassing when she struggles to start.
I’ve been putting a lot of time and effort to get it where I want it aesthetically and it’s almost there so now it’s all about the mechanical things.
Old Jun 27, 2022 | 09:41 PM
J doubleU's Avatar
Nice, what's not too love about an incredible car? You're on your way to figure it out and it will be rewarding.
Old Jul 25, 2023 | 01:39 PM
GOF's Avatar
GOF
GOF is infamous around these parts
Did you find a solution to the problem?. I have the same issue with my car.
Old Jul 25, 2023 | 06:06 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
It’s looking good…hope it’s a simple fix…
Old Jul 28, 2023 | 08:59 AM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
Mine does that as well when the weather is hot...
Old Jul 29, 2023 | 06:50 AM
embdenb's Avatar
Could be the one way fuel pump check valve. Put a code reader on it. It should throw a code.
Old Sep 13, 2023 | 07:22 PM
GOF's Avatar
GOF
Thank you. I will check if there are any codes
msark
May 21, 2022 09:56 PM
TarHeelVantage
Feb 9, 2019 11:46 AM
captain Greg
Apr 22, 2013 10:34 PM
danielg69
Apr 9, 2010 10:18 AM
