A/C issues wiring diagram needed
Old Aug 14, 2022 | 03:17 PM
Maccavvy's Avatar
Maccavvy is infamous around these parts
Hey guys had some issues with my air con.
found a leak on the condensor. So replaced that.
Had it leak /vacuum tested and refilled
Clutch will not engage.
Got earth at clutch but no live.
Switch lights up
Fuse.is fine
Is there a relay ? Or a diagram so I can check continuity along easy section, nothing showing on diagnostics.
Thanks in advance
Old Aug 14, 2022 | 04:34 PM
MRCW's Avatar
It would be helpful to know what kind of car you have
Old Aug 14, 2022 | 04:44 PM
Maccavvy's Avatar
Sorry silly me
07 v8 vantage.
Air con was cold. Over a month air con went warm, diagnosed leaking condensor ,changed and refilled
Vacuum and leak tested .
3/4 days later..driving car air con wasn't cold.
Used high revs to overtake a car ,system went cold
Unable to replicate since that day.
Today no power to clutch
Earth continuity is fine
No power at fuse 10
Switch lights up on dash.
Old Aug 15, 2022 | 01:43 AM
a102768's Avatar
a102768 is infamous around these parts
This is from a workshop manual published in 2008 so may be applicable to your car.
File Type: pdf
Old Aug 15, 2022 | 03:11 AM
Maccavvy's Avatar
Thanks I'm sure that will be handy
born2boost
Aug 28, 2013 12:36 AM
turbo_banker
Jun 1, 2011 05:29 PM
bludemon
Sep 29, 2009 02:30 PM
