Brake Squeal TSB
Old Sep 27, 2022 | 03:15 PM
greatcrimson's Avatar
5 Year Member
greatcrimson is infamous around these parts
Unhappy Brake Squeal TSB
I have a 2019 Vantage which I purchased with ~10K miles on it. From the first time that I drove it I heard the classic annoying front wheel brake squeal. I hoped that it might go away over some time, but it has not, and frankly, it’s embarrassing when I pull up at an exotic car show and every time that I touch the brakes they squeal. I was therefore very please to read on this site, under “Technical Service Bulletins”, that there is a TSB that AM has issued to address the problem. So, I called the closest AM dealer and discussed the TSB with the Service Advisor. He wasn’t aware of the TSB, so he looked it up, and then informed me that the “fix” that AM has developed involves putting some “goo” on the back of the pad to help silence the noise. I used this approach on a car years ago, and it works for a while, but it only addresses the symptom, not the problem. Eventually the squeal returns (which I understand is likely due to glazed pads). Also, since my car is no longer under warranty, there is a hefty service charge to perform the TSB.
The AM Service Advisor also said that the longer-term (or “real”) fix is to have the pads replaced with the newer version of pads that AM now uses. ~$1,500 for that fix. Maybe it’s just me, but for the price one pays for these cars, even used, I would think that the manufacture would “correct” this kind of flaw without charge. Especially since they know that the original pads are defective, and they have a fix. I get that brake pads are a maintenance item, but this problem is not solely due to wear.
Oh, and if you buy the AM extended warranty, which starts at $4,500 for 1 year, it doesn't cover maintenance items, so the brake pad fix would not by covered. Pretty disappointing ...
Old Sep 27, 2022 | 07:04 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
Tunap is the anti squeal they use on the back of the pads and it works. My factory pads have absolutely no squeal at all.
Old Sep 27, 2022 | 10:36 PM
V12Vin's Avatar
V12Vin
Brake squeal could be cool cos it sounds like a track/race car. Nothing embarrassing.
I feel that every manufacturer has a TSB on this. Even Porsche made a video about it.
Are your brakes ceramic or iron? If iron, see if the cross drilled holes are "packed" with brake dust. Clearing them helps a bit. Also check the pads retainers/springs, maybe gunk gets in them. If you really have time, just removed the calipers, inspect all the components, give them a good cleaning.
btw I use AGS SIL-Glyde. Amzn has it for under $10. Pretty solid stuff.
Old Sep 28, 2022 | 07:16 AM
J doubleU's Avatar
Switch to Porterfield pads.
Old Sep 28, 2022 | 08:49 AM
007JB's Avatar
007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light
I had oem pads on my car for long time, never had squeal, switched to porterfield to get rid of brake dust, now they squeal a lot, I may switch back to factory pads.
Old Sep 30, 2022 | 07:20 AM
5 Year Member
Well, it looks like there are several experiences and several points of view on this topic. I appreciate everyone’s input, and now I’ll have to decide which direction to go.
Old Sep 30, 2022 | 10:56 AM
zuman's Avatar
zuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud of
I had great success with BG Stop Squeal. It's a "goo," but it was an easy DIY application. It worked wonderfully on whatever awful squealing pads were on my DB9 when I bought it. I now use Porterfield pads, but the BG Stop Squeal worked for about three years until I replaced the old pads. Under $20.
Old Sep 30, 2022 | 04:08 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
Holy smokes, who knew that pad squeal was still a thing? I put Porterfields on mine but realized quickly that I wasn't "man enough" to handle the squeal. I even bought some brembo brake grease to try and calm them. Found some knock off semi-metallic pads for the Porsche Cayenne and put them on instead. It still stops fine but doesn't light my neighborhood up at 6AM when I sneak out.
Old Oct 6, 2022 | 09:24 AM
downeaster1's Avatar
downeaster1 is infamous around these parts
I have OEM's on my 15' V8V GT, and they make a stupid amount of noise. I was going to switch to Porterfields, but after reading this thread, I'm not too sure now. I've already disassembled the front and rear and applied more brake grease, but without much success. Haven't done the parking brake pads, but I wouldn't think that would affect it.
Old Oct 6, 2022 | 01:57 PM
007JB's Avatar
I'm planning to apply BG stop squeal on porterfield pads & see how it goes before switching back to oem ones.
Old Oct 6, 2022 | 05:53 PM
Semitone's Avatar
Semitone is infamous around these parts
I saw 3 TSBs ( IIRC) regarding brake squeal in the DB11. The fact there are three just makes me feel that Aston doesn’t really have a good handle on the cause.
I have 2019 Vantage with OEM brake squeal. No squeal after I wash the car for about a few hundred miles. No squeal when the brakes are cold or after heavy use. Squeal is pretty much limited to around town leisurely driving after the brakes warm up a bit.
Well, that’s my brake experience. Given all I’ve read about it, I’ve just learned to live with it rather than drive myself batty randomly trying fixes. YMMV.
Old Oct 7, 2022 | 09:44 PM
Davil's Avatar
Davil has a spectacular aura aboutDavil has a spectacular aura about
FWIW the pads on my MY18 sounded like a garbage truck coming to a stop. Replaced with the Porterfields and they are 99% silent. If I’ve been driving very slowly for an extended period there can be a tiny bit of noise but very tiny. Just braking decently once fixes that. Highly recommended.
Old Oct 9, 2022 | 04:32 PM
Joffs Aston's Avatar
Joffs Aston
Does anyone have a suggestion for replacement aftermarket pads for the 2019 Vantage. The factory wants $1500 and I'm not having any luck finding aftermarket
pads
Old Oct 9, 2022 | 04:36 PM
J doubleU's Avatar
Porterfields about $500 F&R
Old Oct 13, 2022 | 01:42 AM
Phil57DBS's Avatar
5 Year Member
Phil57DBS is infamous around these parts
