Brake Squeal TSB
Old Oct 13, 2022 | 09:32 AM
Joffs Aston's Avatar
Joffs Aston
Do the Porterfield's reduce the brake dust.? The stock brakes are horrible for dust
Old Oct 13, 2022 | 09:54 AM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
Just put Porterfield street pads on my own Vantage in September. Significantly less dust; definitely squeal. I will be rectifying the squeal with some anti screaming goop in the near future I think. At the same time, it defeats Doug DeMuro's problem of people not noticing that you're driving at Aston, so I got that going for me now.
Old Oct 13, 2022 | 12:34 PM
slkret123's Avatar
5 Year Member
slkret123 is infamous around these parts
So, I have a 2007 V8V with 2,300 miles. The brakes squeak and it drives me crazy. After the brakes warm up, the squeaks go away. Still..... I read a lot of good reports about using BG Stop Squeal. so, I bought 2 bottles and soaked the pads in a pie tin. The stuff worked for about 25 miles and then the squeak returned. This winter I plan to install a set of Porterfields that the guy at Red Pants seems to like.
We'll see in the spring.
Steve
Old Oct 14, 2022 | 09:05 PM
Davil's Avatar
Davil has a spectacular aura aboutDavil has a spectacular aura about
You did skim your discs right?
Old Oct 14, 2022 | 09:36 PM
slkret123's Avatar
5 Year Member
Davil: Help me out with what skim disks means.
Steve
Old Oct 15, 2022 | 05:47 AM
slkret123's Avatar
5 Year Member
Ahh..I Googled skimming brake disks. I guess that might help in some instances. In my case, I've only got 2300 miles on the car and the disks are pristine.
A lot has been written about the need to bed in new brake pads / rotors to prevent or eliminate squeal. It is not clear why this is needed. Before I retired, I was in the auto industry and I can tell you that auto manufacturers do not do this to new cars. Over the years I've owned a lot of cars and the only one with squeaky brakes is my V8V. I've probably done a dozen of so brake jobs and never bedded any of them.... no squeals. So there must be something else goin on here. Clearly people have this problem with other cars too based on the number of products on the market purported to fix the problem. I don't claim to have a solution, I'm just looking for one.
Steve
Old Oct 24, 2022 | 03:29 PM
DonBond's Avatar
DonBond is just really niceDonBond is just really niceDonBond is just really niceDonBond is just really nice
Try using the brakes like you stole it and are outrunning the cops. Use them hot and heavy and see what happens. You've got nothing to lose. I suspect many of these brakes are glazed due to light use.
Old Oct 25, 2022 | 05:56 AM
zuman's Avatar
zuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud of
Once again, Steve McEvoy has the information we need. Apparently, different brake pads are bedded-in differently; here's the Porterfield procedure (which worked perfectly after I changed mine): https://aston1936.com/2019/10/24/bed...age/#more-4093
Old Oct 26, 2022 | 06:53 PM
61mga's Avatar
61mga is infamous around these parts
i removed the OEM pads from my 2007 vantage v8 and bought some very inexpensive EBC pads from ebay, then applied some copper based grease on the interface between the metal backing plate of the pad and the brake pistons. it is still quiet after about 10,000 miles. did the same and worked on my porsche cayman too.
i know better than to waste good money on brake pads for street use.
Old Oct 27, 2022 | 07:38 AM
UNDRPSI's Avatar
UNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond reputeUNDRPSI has a reputation beyond repute
I recognize that you may not have meant to be cavalier about this, but.... tires and brakes are the most important safety aspects of a vehicle. These are two places that I will not cut corners to save a few bucks for both my own safety and of those around my vehicles.
Old Jan 24, 2023 | 06:35 AM
Redisc's Avatar
Redisc is infamous around these parts
Are you using ceramic or steel?
rnl
Apr 17, 2014 06:50 AM
yrralis1
Cayenne 958
Mar 12, 2014 10:29 PM
BLKPPR
Cayenne 955/957
10
Dec 19, 2010 01:17 PM
racer_65
Cayenne 955/957
Aug 9, 2008 04:31 PM
carbonissimo
Aug 4, 2005 03:47 PM
