What does this mean…..
Old Dec 11, 2022 | 10:35 AM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
What do this mean? I got a CEL out of the blue. I have 4 oem O2 sensors and new spark plugs. The coil packs are still original and I plan to change them next spring. My V8V is a 2007 completely stock and has 24,700 miles. My reader does not give codes just what you see. The second fault say cylinder 12 which is strange sine have an 8 cylinder car. Are engine control module a coil pack? Any and all thoughts are welcome. Thanks.
Old Dec 11, 2022 | 11:38 AM
Hedged's Avatar
Hedged is a jewel in the roughHedged is a jewel in the roughHedged is a jewel in the rough
You need to go to the next level which will show the specific P code(s). Could be one of many issues, such as a vacuum leak, o2 or MAF sensor, throttle body engagement, etc.
You may see the same set of codes under both 1 & 2. I use the NT530 for my 4.7 and have seen the same “cylinder 12” reference, and have assumed the indicated cylinder bank is what matters.
Old Dec 14, 2022 | 12:45 PM
Argus's Avatar
I have a P1000 code for both banks. Any idea what should I start with? I was planning new coil packs, air filters and cleaning the mass flow sensors. Any ideas would be helpful
Old Dec 14, 2022 | 06:53 PM
Hedged's Avatar
My understanding is that P1000 indicates that your car has not completed a necessary drive cycle (System check not completed since last memory clear).
Old Dec 15, 2022 | 02:48 PM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
YES, a P1000 is on the Ford platform. It is usually set if you erased codes or even disconnected the battery. After all the drive cycles reset (can be done with some normal driving time in different conditions - stop/go and some steady state 45 mph) then the P1000 will change to P1111.
If you happen to need an emissions test done with many states that just use an OBDII hookup, you'll fail the emissions test with a P1000
Clancy C.
Jan 7, 2021 07:14 AM
dahveedem
Sep 7, 2019 04:01 PM
xmaciek82x
Jul 26, 2016 05:58 PM
06Turbo
Cayenne 955/957
Jun 26, 2011 01:04 AM
Sharkys
Sep 4, 2010 02:48 PM
