2012 Virage Brake fluid Replacement Procedure?
Old Mar 15, 2023 | 04:21 PM
2012Virage's Avatar
2012Virage is infamous around these parts
Anyone have the complete brake fluid replacement procedure, including the ABS?
Old Mar 15, 2023 | 07:10 PM
V12Virage's Avatar
5 Year Member
V12Virage
Not aware of any of the after-market OBDII systems that include the ABS flush function for the Astons. You will likely need an AMDS for that. The rest of the Virage's system can be flushed in the usual way, though that can be made easier with a vacuum or pressure bleeder. That leaves you with having to flush in two stages: new fluid in the reservoir and bleed the lines, followed by a run in a quiet place to trigger the ABS a couple of times. You should then be able to bleed the lines again to clear out whatever fluid was previously in the ABS module.
Old Mar 15, 2023 | 08:01 PM
2012Virage's Avatar
V12Virage, thank you for the reply.
I'm going to see if my THINKDIAG will show the ABS flush, if not I'll go ahead with the two stage Vacuum bleeder scenario.
Update: Just checked my THINKDIAG and apparently it has an "ABS flush" function.
Old Nov 8, 2025 | 12:31 PM
AM-DB9.2's Avatar
AM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of light
Hi,
Did you use the "ABS flush" function on your THINKDIAG? Did it work?
Scotty4300
May 7, 2015 09:26 AM
jbsport
Cayenne 958
Nov 14, 2013 07:50 AM
Vergis
Apr 1, 2013 07:36 PM
dinorocz
Nov 2, 2010 01:54 PM
r34dy2walk
Feb 28, 2008 05:40 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
