DBS issue - car shudder at idle, random minor ticking
Old Jul 12, 2023 | 08:25 PM
DBS down under's Avatar
DBS down under is infamous around these parts
Hi all, over the past week or so, my V12 DBS has developed an occasional minor tick and occasional rough idle (via noise, not the rev meter). This morning on the way to work, I received an "emission system required" message along with the amber CEL and a red exclamation to drive slow, urgent service required. These messages both turned off and car operation resumed normally when I restarted the engine. Does anyone know what this may be and whether it's a terminal risk? Checking for advice before I scan codes or visit mechanic. Car has a tune and full catless header back exhaust system recently installed, 40,500 km mileage and recently serviced...could this be the dreaded ticking issue in DB9s?
Old Jul 13, 2023 | 06:11 AM
Liilpa09's Avatar
5 Year Member
Liilpa09 is infamous around these parts
Have the coil packs been replaced recently? Could be the cause of the shudder.
Did you check the oil level?
Old Jul 13, 2023 | 11:40 AM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
Might be good to have the fuel pressure checked out. I've had a slightly rough idle on my DB9 for a while now. No CEL yet, but I did verify the fuel pressure dies off on one bank almost immediately after shutting the engine off. It's supposed to maintain pressure for 12-24 hours, which the other bank on mine does.
Old Jul 14, 2023 | 02:33 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
I highly recommend a OBDII reader. My foxwell NT520 is really helpful at figuring this out. It will pay for itself in the first use. You are like a blind man chasing Angelina Jolie on a football field without one...
Old Jul 14, 2023 | 02:53 PM
GA_DB9's Avatar
5 Year Member
Agreed 100%. I've got the NT530. It's probably functionally identical to the NT520 It knows the AM OBD PIDs and gives a lot more information than a generic OBD reader.
Old Jul 15, 2023 | 11:21 PM
Thanks everyone - OBD scanner on the buy list. I connected the VAP ECU tuning unit and received error codes B1600, P1000 and P1582...I've cleared these and will see if they return to investigate further. I just finished a 30 min drive and seems to be normal again (for now).
ajmevans
May 21, 2019 11:14 AM
Chris P
Jul 26, 2018 08:44 AM
twilight997
Jul 28, 2011 03:21 PM
StuM
Sep 5, 2009 05:09 AM
