DB9.2 wheel spacers
Old Jul 21, 2023 | 03:26 AM
huesey1974's Avatar
huesey1974 is infamous around these parts
DB9.2 wheel spacers
Hi,
i am looking to fit some spacers to my 2013 DB9.2, i see loads of info on Vantage and earlier DB9’s however not much for the later model. I have 23mm rear and 11mm front H&R spacers. Fronts I believe are ok as the come with the lug nuts with extra thread, any experience with the 23mm rears? Seeing some issues with the bolt extending past the spacer and the wheel not fitting without trimming. I believe my wheels have pockets looking at a set on ebay but has anyone experienced any issues on this model?
thanks
Old Jul 21, 2023 | 07:24 AM
95viper's Avatar
95viper is infamous around these parts
Originally Posted by huesey1974
Hi,
thanks
Buy a high quality set because nothing is worse than a slight shimmy. H&R 4665681 are perfect but validate for your model.
23mm isn’t even an inch so yes they will extend past the spacer. If your wheels have pockets that align you are good. If not sure they can be cut down but if you ever go back to removing the spacers you will have to install new hub bolts. Not a lot of drama but just to know.
To validate remove a wheel and measure the distance the bolt extends from hub. Anything past 23mm….
Old Jul 21, 2023 | 07:47 AM
huesey1974's Avatar
Hi,
Thats the ones i have bought, im sure my rims have pockets but can’t check for sure as i work abroad. The Mrs will take it to have them fitted along with new tyres so soon find out i guess!!
thanks
Mat59
Jan 27, 2015 08:26 AM
kparis
Mar 26, 2012 09:59 PM
DocN
Mar 29, 2010 05:57 PM
jaewoo0
Nov 16, 2005 12:45 PM
sentipede
Aug 10, 2003 12:09 PM
