V8V creaking steering
Old Nov 21, 2023 | 01:30 PM
MRCW's Avatar
Have creaking sound with turning wheels at low speeds ... does the front end need grease?
Old Nov 21, 2023 | 02:40 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
I’m guessing you have checked the steering reservoir level..may need a fluid change..and checks for leaks..
Old Nov 21, 2023 | 02:52 PM
MRCW's Avatar
yes. Fluid is full with Petrosin and also has lubrizol...
I'm thinking some bushings may be worn... steering is tight, high speed and even on bumps...
Old Nov 22, 2023 | 08:49 AM
embdenb's Avatar
Could be anything from a steering rack issue to worn suspension parts. The squeaking is probably your starting point. Find out what’s squeaking and go from there.
Old Nov 27, 2023 | 10:44 PM
GWP's Avatar
GWP
5 Year Member
GWP is infamous around these parts
Make sure your wheel nuts are tightened to 140 ft/lbs. That cured mine.
keitheva
Apr 16, 2019 11:45 PM
simoncpw
Jan 6, 2015 09:06 PM
nubarjan
Nov 23, 2005 09:03 PM
PorschExtremist
Jul 30, 2004 11:13 PM
