2006 V8V - clunk in steering
Old Aug 22, 2016 | 11:46 PM
keitheva's Avatar
keitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of light
Recently my 2006 V8V has developed a clunk in the steering. It happens when turning at full lock, especially in reverse. There is no play in the steering, wheel wobble or anything else indicating a problem. There is a very slight vibration in the steering wheel when it happens. It feels/sounds like something in the steering shaft itself, rather than at the box/wheels.
Any ideas?
Tia.
Old Aug 23, 2016 | 06:38 AM
BillV8V's Avatar
BillV8V has a spectacular aura aboutBillV8V has a spectacular aura aboutBillV8V has a spectacular aura about
My 07 did that with the wheel turned all the way to the left, they said it was a bent sway bar end. They replaced it and it went away.
Old Jul 26, 2018 | 01:44 PM
keitheva's Avatar
Any ideas?
Tia.
Update, still have this issue. Two shops have tried and failed to find any cause in the suspension or steering systems. The sound happens intermittently on full lock travelling either forwards or reverse, left or right, slow and fast speeds. It very much sounds like its coming from somewhere around the steering column. It hasn't gotten any worse with time, and other than the noise there are no other symptoms. It does sound like a dry joint somewhere.
Revisiting this to see if anyone has any new ideas.
Old Jul 26, 2018 | 02:22 PM
keitheva's Avatar
Originally Posted by Redpants
Checked all the bushings, especially control arms?
Yes, the two shops both went through all the steering and suspension components and found nothing untoward.
Old Jul 30, 2018 | 12:50 PM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
Stupid question but have you looked at the airbag bushes in the back of the steering wheel assembly?
dont give me the finger ...your car is at the age where these little plastic spacers could need replacement they cost nothing and make a big difference.
I say this having owned a Merc SL when I was a bit younger the previous generation that still had grace and personality and a removable hard top .....it developed a knock that I swear came from the exhaust system....on investigation it was found to be the rubber grommets on the windscreen support frame ?
Some noises can be deceiving i replaced my airbag bushes got them from Aston bits for like a pound incl shipping but sure Redpants will have stock
just check it it will save some grey hairs
Old Jul 30, 2018 | 01:17 PM
keitheva's Avatar
Thanks!
Pardon my ignorance, where exactly are these and how do I check them?
Old Jul 30, 2018 | 02:31 PM
J doubleU's Avatar
Old Jul 30, 2018 | 02:38 PM
keitheva's Avatar
Thanks!
It's not a rattle, just a one-off, "clunk" every now and then on full lock with very minor feedback through the steering wheel.
But it's worth ruling out all possibilities.
Old Apr 15, 2019 | 10:43 PM
Quang's Avatar
Quang is infamous around these parts
Thanks!
Mine seems to have the same click-click noise
Have you resolved the issue?
Old Apr 16, 2019 | 11:49 AM
keitheva's Avatar
Nope. Still happens occasionally. My working theory is a dry joint somewhere. It hasn't gotten any worse so I'm not bothered about it.
Old Apr 16, 2019 | 11:56 AM
Quang's Avatar
Thanks. I am afraid it's getting worse eventually. Thinking of to have Porsche dealer to inspect it.
Old Apr 16, 2019 | 07:40 PM
JL_MPLS's Avatar
JL_MPLS is infamous around these parts
I had a similar issue (not a clunk, but a repeated clicking sound (think rachet sound). It was the clock spring in the steering column for the airbag. Hope this helps.
Old Apr 16, 2019 | 11:25 PM
Quang's Avatar
Thanks. The sound come from under the car. Could it be drive axle or transmission?
Old Apr 16, 2019 | 11:45 PM
plastique999's Avatar
plastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to all
Interesting, I am noting similar symptoms as well...going to have my friend’s shop inspect it and will update with any info.
Juanna Knowtrooth
Cayenne 955/957
Apr 24, 2016 02:43 AM
jaymcars
Apr 14, 2016 11:16 AM
Shawn C
Aug 9, 2003 02:07 PM
