V8V - Yaw Rate Sensor location
Old Dec 20, 2023 | 01:43 PM
scapesandshapes's Avatar
scapesandshapes is infamous around these partsscapesandshapes is infamous around these parts
Ive got a Yaw Rate sensor fault which is causing DSC errors. Seems that I can get the parts cheap online so its easy to just a matter of flipping that part new.
In the service manual it states "located centrally on the transmission tunnel".
Can any one point me in a more specific direction? how to access?
Old Dec 21, 2023 | 09:55 AM
TR-Spider's Avatar
5 Year Member
TR-Spider is infamous around these parts
The module locator in the workshop manual shows the yaw sensor close/below the nav screen.
I GUESS you have to remove the "waterfall" for acess.
Old Dec 21, 2023 | 11:18 AM
Hedged's Avatar
Hedged is a jewel in the roughHedged is a jewel in the roughHedged is a jewel in the rough
Per Scuderia catalog for Sensor-Yaw Rate (see also their parts diagrams).....
Part Number: BG33-14B296-CA, the less expensive sensor, fitment for V8VS and the facelift 2012.25+ 4.7 Vantage.
Part Number: 4G43-90-10897, the expensive sensor, fitment for earlier Vantage, DB9 ('04 to '12), DBS and Rapide.
Per the Aston Martin On-Line Repair Time Searcher (RTS)....
"06.09.EB - Yaw Rate Sensor (Remove and Install New Part) V8 Vantage Roadster (only model that came up) 5.65 hours," which involves "0112AB - Instrument Panel - Facia Assembly (Remove for Access and Install) This procedure is not used in any other procedure."
Looking up just 0112AB accounts for 5.45 hours, so that's what you are dealing with.
Old Dec 22, 2023 | 06:47 AM
embdenb's Avatar
If it took me 6 hours to get to it I might just unplug it and forgot about it (smile)
Old Dec 25, 2023 | 01:33 PM
We located the yaw rate sensor, it is indeed behind the radio unit.
It is held in place by two studs with nuts. Right in its way of removal is a dash support bar. So you need to create about 3/4in of space to remove/replace it.
Why they used a stud instead of a bolt is a bit mind-boggling given it would be about 30 second part change if they had. Also quoted a ridiculous price for the part from AM, however they are available on Ebay quite cheap. Hopefully I can test the new part as the solution to my DSC issue by just plugging it in without installing it for confirmation.
exilebrit
Jan 24, 2024 07:50 AM
oo7
Sep 19, 2019 07:25 AM
MikeR397
Jun 6, 2019 07:45 AM
barncobob
Dec 8, 2014 01:30 PM
DNugget991GT3
Aug 19, 2008 10:21 AM
