Foxwell Help!!
Old Feb 28, 2024 | 06:23 PM
Sir Rothschild's Avatar
Sir Rothschild is infamous around these partsSir Rothschild is infamous around these parts
Foxwell Help!!
Having issues with my Foxwell NT530 scanner (or maybe I just don't know how to use it). The scanner only powers off when it is plugged into the ODB2 but the engine and accessory are on. When I attempt to turn on the accessory (#2), or ignition the screen goes blank and turns off.
Hoping there's some help out there for this. Much appreciated.
Old Feb 28, 2024 | 06:38 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
Originally Posted by Sir Rothschild
Having issues with my Foxwell scanner (or maybe I just don't know how to use it). The scanner only powers off when it is plugged into the ODB2 but the engine and accessory are on. When I attempt to turn on the accessory (#2), or ignition the screen goes blank and turns off.
hey..not sure I can help..but foxwell model might be useful…cheers
Old Feb 28, 2024 | 06:50 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
Not sure what year AM you are attempting to connect to. Some models have 2 ports
Old Feb 28, 2024 | 06:51 PM
Trying to connect to drivers side port to read engine codes. It’s a 2012 V12 Vantage
Old Feb 28, 2024 | 07:50 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
My foxwell works great. Plug it in with engine off, turn key to accessory, read codes...
Old Feb 28, 2024 | 09:32 PM
Think I figured it out. The unit seems to work with the USB plugged into some power source in addition to the ODB2. So perhaps the issue is that it cannot hold a charge….
Old Feb 29, 2024 | 08:24 AM
AM-DB9.2's Avatar
AM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of light
for what its worth - I have the NT530 and it obtains its power from the ODB2 port. Never experienced the issue you are seeing, and have used it on 3 different makes of vehicles.
farfel
Jun 15, 2011 09:59 PM
mptoledo
Jun 30, 2009 09:47 PM
rzundel
Jan 23, 2007 11:17 AM
