Alternative sourcing for AM PCV valve?
Old Mar 10, 2024 | 05:59 AM
sweet991S's Avatar
5 Year Member
sweet991S
Happy Sunday all - just wondering if anyone has been able to locate a non-AM positive crankcase ventilation valve - AM part is almost $150. Thinking that perhaps Ford or Volvo makes the identical one. I am unable to conduct that kind of research but DO know that last week my new Fav shop was able to use Ford 02 sensors to replace the factory ones that were 14 yrs old and prone to failure. The Ford ones were significantly less money BTW.
MTIA!
Old Mar 10, 2024 | 12:35 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
It looks like Steve at Aston1936 uses Motorcraft EV-152D on has a DB9. If I had a DB9 I would follow what he says. He looks to be the best read and best researched guy out there hands down. Amazon has a kit for $25.
Old Mar 10, 2024 | 03:52 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
MTIA!
Are you seeing oil down in your air filters?
Old Mar 10, 2024 | 04:51 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
the Motorola EV-152D is the pcv used by AM. I used a catch can modification suggested on this forum (from JEGS) that catches about 2 teaspoons of oil on each bank every 1000 miles...
Old Mar 11, 2024 | 04:41 AM
sweet991S's Avatar
5 Year Member
sweet991S
No sir--
Old Mar 11, 2024 | 04:51 AM
sweet991S's Avatar
5 Year Member
sweet991S
Ok - here is a pic of the Motorcraft --- Call me crazy BUT the two don't really look alike. What am I missing ?
This is my PCV valve (note small oil leak on LL quadrant)
Old Mar 11, 2024 | 07:37 AM
J doubleU's Avatar
That's an AOS which is around $60.
Old Mar 11, 2024 | 10:02 AM
sweet991S's Avatar
5 Year Member
sweet991S
This one is on ebay for 99bucks -but is for the 4.3 V8.....here is my QUESTION - will it fit the 4.7L motor? It appears that it will but I am not a Tech by any description. Thanks All!
Old Mar 11, 2024 | 10:21 AM
sweet991S's Avatar
5 Year Member
sweet991S
Never mind - it WILL fit (same part # ---duh)
;-). don't I feel silly--
Old Mar 11, 2024 | 10:26 AM
mthdr's Avatar
mthdr is infamous around these parts
The PCV valve you show is the one for the V8, it is used in range rovers. Atlantic British carry them for about $70; I believe the motocraft one is for the V12. I ordered one to replace mine as it was starting to buzz but the replacement made such a horrible noise I put the original back on and have ordered one along with the air oils separater from scuderia. Hopefully that one is better.
Old Mar 11, 2024 | 11:27 AM
J doubleU's Avatar
They are the same on 4.3 and 4.7 dealer list price is $61 even if they mark it up it should be less than $100.
Old Mar 11, 2024 | 11:42 AM
J doubleU's Avatar
Just searched part number and ML performance has it for $51.
Old Mar 11, 2024 | 11:03 PM
EJ_Rapide's Avatar
Is oil in the PVC line a sign of a failing/failed AOS?
Old Mar 12, 2024 | 04:48 AM
sweet991S's Avatar
5 Year Member
sweet991S
Dealer wants 299.00 DOLLARS.....whatever they're smokin, I want some......geez
Old Mar 12, 2024 | 04:51 AM
sweet991S's Avatar
5 Year Member
sweet991S
JW ---
Genuine Aston Martin 6G43-01-10086 Crankcase Ventilation Valve. - their price is $155.00, just fyi
