looking for a 'no drill' or tow hook front licesne plate mount
Old Mar 21, 2024 | 11:28 AM
mbrandt1402's Avatar
mbrandt1402 is infamous around these partsmbrandt1402 is infamous around these parts
Ebay: https://www.ebay.com/itm/303304917869?itmmeta=01HSH0PF49TP239CW6QZDPF86P&ha sh=item469e61c36d:g:a58AAOSwPGBdkt4l&itmprp=enc%3A AQAJAAAA8HD80zqArL%2BAqnMYnv3qg5IbD%2BKS2g%2BXcOEv wALr5Uo5rNefDXmLBtJFEUcKriTFQ5AvunMBGaifeJMfItFYqk dl%2B4D1FEDUIxFNEv9947SqZFk4OKhx9B6sCN%2BRdrccrtm% 2FmKY7p4BQLbgVV9G%2FrlXQojHKt%2FbNVJlDptajsbhkjIDv %2BoEnOtdXHzy0COkeeHeKzDpS4MmbPe1IDzNH3yz5TkEKAUE8 VKfsdOdhgv8KZ0bHjHm4HNGcjQQFDG5MMAPQ%2BLh9tfpsvvmD Y9oRzu87AVS4Ymbt1CEmWPyAZ4m8HJ7HffbIOZBJr4cclre7pw %3D%3D%7Ctkp%3ABk9SR6zy2aDMYw
I haven't installed mine yet, but the kit looks to be of decent quality.
Old Mar 22, 2024 | 05:59 AM
sweet991S's Avatar
5 Year Member
sweet991S
Thanks MBrandt! I will buy this IF I cannot create//McGiver my own solution.....! When(IF?) I get my V8V back from brain surgery (trying to clear out the smog errors), I will see if the front tow eye may be an option. Does AM provide only one tow eye for both front and rear?
Old Mar 22, 2024 | 08:40 AM
J doubleU's Avatar
I have a new in open package one if anyone is interested. Trade for ??
ID:	545096   Click image for larger version
Old Mar 22, 2024 | 09:39 AM
sweet991S, regarding just one tow hook:
The car IS aluminum, but I don't think you could stretch the wheelbase just by towing from both ends at the same time.
Old Mar 24, 2024 | 02:05 PM
sweet991S's Avatar
5 Year Member
sweet991S
Okay - that's fair! When/if I ever get the car back I will pursue my McGiver-esque solution to this (not really) vexing problem........... ;-)
Old Mar 25, 2024 | 05:26 PM
khiroshima's Avatar
khiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond repute
Here is what I use:
Amazon Amazon
Amazon Amazon
The published review (kh) is me - it uses an existing hole and double sided tape, works perfectly and you can easily decide if you want a plate or not! Good luck, KH
Old Mar 26, 2024 | 04:41 AM
sweet991S's Avatar
5 Year Member
sweet991S
KH - I wonder if this bracket thing might work for my MY 2010 V8V ? Any thoughts?
Old Mar 26, 2024 | 09:29 AM
khiroshima's Avatar
I am quite pleased with the setup, it is quite secure and I have run it at speed (meaning faster than the speed limit, but nothing that would send "you" to jail) with no issues
If you have space (probably 3-4" of flat and clean) splitter to work with, I believe it will work fine. And since it's the bottom of the bumper/splitter, I would be even comfortable drilling, as it will never be seen
Full disclosure, I have since sold my Vantage and now have an SL63, I removed the bracket from the Vantage before selling and plan on doing what I just suggested (to you) on the SL (I just need to replace the 3M double sided tape)
I run without a plate most of the time, but in SF, they will ticket parked cars; so it is super convenient to park, slap the plate on when parked - Feel free to send me a pic of your situation and I'd be happy to weigh-in; else, double check Amazon's return policy
Old Mar 26, 2024 | 10:32 AM
sweet991S's Avatar
5 Year Member
sweet991S
Many Thanks KH!!
Old Mar 26, 2024 | 10:41 AM
khiroshima's Avatar
Many Thanks KH!!
Hmmm, I just went to their website and I don's see direct support for the 2010, but I just don't see why it wouldn't work . . . https://stonsho.com/
Old Mar 26, 2024 | 10:57 AM
sweet991S's Avatar
5 Year Member
sweet991S
Thanks! First, what is the cost? Second, are you familiar with the Vantage front end for that era (mine is a 2010)? And if so, you do think the STO n' Go would be easy to attach to the underside of the front fascia/bumper?
Old Mar 26, 2024 | 11:19 AM
khiroshima's Avatar
I included links, $97.99 from Amazon
If you want to experiment, make sure you understand the return policies
Not familiar at all with the 2010, but one hole and 3M double sided tape . . . Seems super simple - one caveat is that in all cases that I have seen, they use a factory screw in addition to the tape, here's the SL version (same approach): https://stonsho.com/products/front-l...l-55-63-sns374
Old Mar 28, 2024 | 05:06 AM
sweet991S's Avatar
5 Year Member
sweet991S
This heavy plastic plate allowed for many options, using the below-pictured "C" bolts, etc. Took a little playin' around with but it worked out well.
straight down into the grill.
I used the #1 glue on the planet (6000) to keep the 4 washers per each side (top), together.
Now I need a thin black silicone tag cover (like 3/8 in or so). Have had zero luck finding such on line.....
Old Mar 28, 2024 | 05:08 AM
sweet991S's Avatar
5 Year Member
sweet991S
Best part? Total expenses including mounting plate, "C" bolts and expandable hooks, washers, and glue was under 15 dollars.
Leslierc
Mar 25, 2024 05:26 PM
rocket94
Aug 7, 2015 12:41 PM
Karman
Jun 12, 2015 12:35 AM
DLJ
Apr 11, 2014 10:14 AM
