Hood adjustment - Fenders adjustment
Old Apr 1, 2024 | 07:48 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Hello all,
I have a slight misalignment between my hood and my fenders.
I need to recenter the hood and lower the fenders (or lift the hood).
The 2 hood stops are already at their highest elevation.
What would be the best way to do that?
Play with the hinges of the hood (#3 below)?
Or play with the fenders bolts on the side?
BTW, how is one supposed to adjust fenders elevation? Just tighten the crap out of the bolts? Or is there a smarter way?
Thanks in advance for any help
Old Apr 2, 2024 | 06:50 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Bring it to body shop.
Old Apr 2, 2024 | 09:47 AM
EJ_Rapide's Avatar
That's an option, too.
Old Apr 3, 2024 | 04:58 PM
sweet991S's Avatar
5 Year Member
sweet991S
Sorry --- Body shop.
Old Apr 3, 2024 | 08:55 PM
J doubleU's Avatar
If you mechanically inclined the lower portion below the wing/fender does have a reverse thread for alignment. If you remove all the adjacent 8mm head bolts per panel to have flex room you can see the lower adjusters. Little trial and error, or maybe alot you should be able to get it figured out.
Old Apr 3, 2024 | 09:54 PM
EJ_Rapide's Avatar
Thank you, I will look into it.
Old Apr 8, 2024 | 04:33 AM
Ray F's Avatar
5 Year Member
Ray F is infamous around these parts
I have had to do this for my DBS recently. The side to side adjustment is best carried out using the hinge bolts on the bonnet/hood, the back and forward adjustment using the hinge bolts on the wings/fenders. They need to be loose enough to move the bonnet/hood but tight enough to retain your adjustment whilst you tighten them up again. It's trial and error I'm afraid, but very doable.
OEkun1
Feb 22, 2018 08:26 PM
rscultho
Sep 24, 2014 04:37 AM
midwestamv8
Sep 6, 2014 11:55 AM
kkswow12
Feb 22, 2012 06:12 AM
Steve Theodore
May 4, 2009 07:08 AM
