DB9 with no Key Fob but Keys?
If a DB9 car (non-crystal key), year 2007, has the physical keys , but no fob, how can I go about getting a fob for programming the remote lock, unlock?
I know it is a volvo part, and people say to swap the electronics over, but problem is I have no electronics in the first place.
I know there is AMDS and also other OBD2 tools that can do the programming.
What are my options?
I bought two "standard" volvo key-fobs and two empty jaguar fobs and swapped the electronics over to them.
Then used Thinkdiag to remove all previously added keyfobs from the CEM module and after that added my own two (make sure you get the seed-codes with the volvo-fobs!).
Easy peasy! No hiccups at all except the range sucks from some angles when approaching the car. I understand this is a common problem though, regardless.
