DB9 2006 Master Light Switch upgrade
Old Jun 27, 2024 | 09:37 AM
bosiarz's Avatar
bosiarz is infamous around these parts
Hi,
I have standard master light switch 8D33-11654-AB without automatic mode. Each time I need to remember to switch on light because I am obliged to do it in my country. When I stop engine, buzzer reminds me to switch it off.
I would like to upgrade switch to automatically switch on lights when engine is running and switch off when stopped.
I noticed that there is a switch DG43-11654-BA which have additional Automatic mode. I hope that installing this switch will solve my problem. Am I right? Maybe this switch use light sensor and switch on lights when it is dim outside?
Could you recommend me working solution? It can be additional light module.
Old Jun 27, 2024 | 10:17 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Old Jun 27, 2024 | 02:03 PM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
Pin 6 on the headlamp switch is wired to the CEM for cars with auto headlamps. For my 2007 with standard headlamps there is no wire in that position on the diagrams. Even If the wire were there it looks like you would also need the rain/light sensor in the windshield (and 2013+ windshield) and coding by AMDS to support both. The car config supports Canadian DRL, but also requires AMDS to configure.
Old Jun 27, 2024 | 02:06 PM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
I had special ordered a new Vantage in 2007 with headlights on as part of an Aston Works upgrade. They charged me $500. Later on I realized they used the Canadian switch.
Old Jun 27, 2024 | 02:20 PM
GA_DB9's Avatar
5 Year Member
$500 to change a 2 to a 3 in the config. Nice. I'm sure that was some sort of minimum charge just to get it into Works.
Old Jul 1, 2024 | 05:57 AM
bosiarz's Avatar
Thank you for all suggestions and informations.
utkinpol
Dec 10, 2020 07:12 AM
roderijk
Cayenne 958
Mar 31, 2018 03:49 PM
r34dy2walk
Nov 19, 2009 07:53 PM
///M Kevin
Tech / How To
Mar 24, 2009 08:22 PM
gneypiks
Jun 18, 2004 10:37 AM
