How to Repair?
Old Nov 11, 2024 | 05:58 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Question How to Repair?
The weather-stripping piece on passenger window is coming loose. How do I repair this? Can it be glued or do I need a new window?
Old Nov 11, 2024 | 09:24 AM
V12Vin's Avatar
V12Vin
Hard to tell from your pic. Are you referring to that twisted section? Has it separated from the pillar?
Old Nov 11, 2024 | 09:32 AM
5 Year Member
Here's an additional picture
Old Nov 11, 2024 | 12:52 PM
UltraMarine's Avatar
UltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to all
I'd heat it up a bit to remove it, clean it and reinstall
Old Nov 12, 2024 | 07:47 AM
embdenb's Avatar
Just b sure to use the correct adhesive for bonding rubber to glass
Old Nov 12, 2024 | 07:48 AM
5 Year Member
Which would be what product?
Old Nov 12, 2024 | 08:40 AM
To bond the plastic strip back onto the glass, there's the easy way and the hard way!
Easy way would be Silicone , it sill take a little bit of time to cure but it will hold nicely.
The hard but permanent way would be with automotive glass/rubber adhesive:
This would mean cleaining the interior of the weatherstrip channel (make sure it's clean and dry and old adhesive is removed , with tooth pick or something),
Priming the interior of the plastic channel with Loctite SF 770
Cleaning the glass and before applying the glue to the weatherstrip, use activator Loctite SF 7455 on the glass edge and door edge where glue will need to contact.
Apply adhesive in the weatherstrip channel, using Loctite 406 , and push in. Make sure you don't use too much so it doesn't get pushed out. It'll set it in quick. It'll be permanent
use mini-clamps where you can to hold the pieces together (especially the piece that sticks out the glass) until it's dry
Old Nov 12, 2024 | 10:02 AM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Does anyone know where we can source one of these weatherstrips?
I haven't been able to find one, and I don't feel like replacing the whole window glass....
Old Nov 12, 2024 | 10:28 AM
I looked into it previously and it's not sold separate from the glass....
Old Nov 12, 2024 | 11:58 AM
EJ_Rapide's Avatar
What does the extrusion look like? Maybe we can find an equivalent?
Old Nov 12, 2024 | 12:08 PM
EJ_Rapide's Avatar
Answering to myself, I can check on my other rear window
Old Nov 15, 2024 | 05:27 PM
DonBond's Avatar
DonBond is just really niceDonBond is just really niceDonBond is just really niceDonBond is just really nice
Glue it back on man….3m trim adhesive
Old Nov 17, 2024 | 04:17 AM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
Good advice!
I've done a few of these (not AMs). This is not the first tube I've purchased.
Old Nov 17, 2024 | 05:58 AM
5 Year Member
Originally Posted by BWings
Good advice!
Thanks, will take a look at the local parts stores for this!
Old Nov 17, 2024 | 06:48 AM
BWings's Avatar
5 Year Member
Just some friendly advice - this material is VERY sticky and it can get out of control. It is difficult to clean up if it gets where you didn't want it.
If you place a bead on a strip and press it down, the bead will spread, of course. So, don't overdo it thinking it needs lots of adhesive. It's worth taking your time, plan it out before you start applying the material.
All the Best with it...
EDIT - Almost forgot. Clean both surfaces with rubbing alcohol first making sure the surfaces have no dirt or film; let the alcohol evaporate, usually a couple of minutes at least, before you apply the adhesive.
