Can I get 12 VDC from under the reading lamp pod on a Vantage?
Old Sep 13, 2025 | 12:16 PM
Tubbs's Avatar
Tubbs
Can I get 12 VDC from under the reading lamp pod ?
I am trying to find 24 HOUR 12 volt power by the rear view mirror for a dashcam... Any Idaeas
Old Sep 13, 2025 | 11:41 PM
PhuketPaul's Avatar
PhuketPaul is infamous around these partsPhuketPaul is infamous around these parts
What year Vantage? Later cars had wiring for a homelink dimming mirror which has 12V but early cars didn't.
Old Sep 14, 2025 | 06:54 AM
embdenb's Avatar
My 2007 Vantage has a home link auto dimming mirror from the factory . I believe the 12 volt connection for the mirror times out after the car is shut down.
Old Sep 15, 2025 | 11:04 AM
Tubbs's Avatar
Tubbs
Thank you for the reply. Yes my car does have the home link on the mirrors. I forgot to check the voltage there. off the little white module with three wires going to it that says Volvo I was only getting 11 volts. I wonder what that little white box is for?
Old Sep 15, 2025 | 01:03 PM
Distwo's Avatar
Distwo is infamous around these parts
You can use a FitDVR box which is plug and play with the home link harness but it powers off with the ignition. This is the one I used on my 2007
Amazon Amazon
Old Sep 15, 2025 | 04:41 PM
MRCW's Avatar
if you need hot all the time pull power from the floor fuse box and run a feed up the A pillar and headliner... it's actually quite easy and can be easily undone.
arne0072
Apr 1, 2024 06:47 PM
LμL
Mar 13, 2023 10:05 PM
msark
May 21, 2022 09:56 PM
PJK
Sep 28, 2021 07:59 AM
