Air Bag Message
Old Jan 15, 2026 | 08:27 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Question Air Bag Message
This message has popped up a couple of times the last month or so. Goes away after a while. Any ideas?
Old Jan 15, 2026 | 09:26 AM
J doubleU's Avatar
Owners book describes how it works with occupancy sensing. Object on seat less than 40 lbs does it.
Old Jan 15, 2026 | 09:32 AM
5 Year Member
There was nothing on the seat (both times the error came up).
When my dog is on the seat (30lb), I get a message on center console, but no icon within the gauge cluster or message to read. FWIW, I think both times the seat was all the way up front.
Old Jan 15, 2026 | 07:36 PM
J doubleU's Avatar
Most likely needs dealer calibration since it's at the front position. I assume nothing under the seat. I would just keep it an inch or so from full front position and see if it happens again. Doesn't sound like a failure or fault just out of calibration. Maybe your dealer would be nice enough to do a friendly calibration at no charge to see if it passes or if something is faulty.
Old Jan 16, 2026 | 06:11 AM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
I get the message anytime my girlfriend puts the seat all the way back and it jams into the parcel shelf. As soon as I move it off the shelf it goes away.
Old Jan 16, 2026 | 07:39 AM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
I had the same issue with a Timeless Certified 2015 V12S that had a ton of issues (previously posted here). Morries Aston Martin told me that was 'normal', but with 3 previous V8 Vantages prior to the V12S I knew it was not. Aston Martin replaced my problem car, but I kept in touch with the new buyer of that problematic one. A month after he bought the car the engine blew up and was replaced under warranty. A rep from Aston Martin flew out to OK the work and authorize delivery, but the air bag warning issue showed up (that I said was not right), they said needed to be fixed. I happened to drop by the Morries shop when they were working on it and the entire interior was apart trying to figure what short or what computer was screwing up (it was not the seat). Not sure what the cause was, but it was impressive to see the amount of work they put into a warning light.
Old Jan 16, 2026 | 12:23 PM
5 Year Member
I am backing it off a hair of being all the way forward. Makes it easier to see out the passenger rear window when the seat is forward.
TimeforaTee1
Bentley
Jul 21, 2025 01:21 PM
Manuel Ruttimann
Jan 6, 2018 08:36 AM
my996
Oct 18, 2010 07:31 AM
steve harris
Dec 27, 2008 04:27 PM
