Oil Change Issue - Second Bypass Filter Stripped
Old Yesterday | 01:34 PM
AMnewb's Avatar
AMnewb
Hey All,
New owner of a 2007 V8 Vantage and when doing the first oil change one of the two bolts in the rear most bypass filter was stripped out/seized as even when the torx was fully seated it snapped it off inside and didn't turn whatsoever. Rather than keep fighting it I just left that bypass filter untouched, put the other bolt back in and refilled with oil.
Is there any concern in driving the car without that bypass o ring replaced? Note that I was able to change the main oil filter, drain plug, washer on front drain plug, and one of the bypass o rings. Replace with new Motul 8100 10w-60 oil as well.
My plan was to drive it for a while and then have a shop address the seized bolt at my next oil change interval.
Old Today | 05:43 AM
embdenb's Avatar
I would not worry about it. Just get it sorted before your next oil change.
Old Today | 08:52 AM
AMnewb's Avatar
AMnewb
Thanks for the response. Was freaking out a bit.
Old Today | 11:50 AM
davidm17's Avatar
5 Year Member
davidm17 is infamous around these parts
Yeah. Very little oil comes out of those. The 4.7 doesn't even have the little filters.
droffsite
Apr 3, 2021 09:46 PM
muker
Mar 4, 2020 08:09 AM
yidal8
Apr 13, 2019 05:09 AM
Vantagelvr
Dec 27, 2014 07:41 PM
Jnocerin
Jul 11, 2009 05:40 AM
