Sponsored By:
Sponsored By:
Oil change Procedure for 2006 S4
Old Feb 15, 2008 | 09:04 PM
Arnie's Avatar
Arnie is infamous around these parts
Does anybody have the instructions on the procedure for changing the oil on my 2006 S4? I will not go 10,000 miles between oil changes. Last time I paid the dealer 150 for an "Extra" oil change I change the oil on my 2003 Porsche turbo which is rather complicated but saves me over 150. I just like to have the instructions to be sure. Thanks in advance
Arnie
Old Feb 16, 2008 | 01:35 PM
adean1979's Avatar
adean1979 is infamous around these parts
Not to be a smart a$$, but remove drain plug/washer, drain oil, tighten drain plug/washer, remove oil filter, replace and tighten with new one, add the amount of necessary oil into the motor that the manual specifies. If you want to be ****, get a new crush washer for the drain plug everytime you change it.
Old Feb 16, 2008 | 09:22 PM
Arnie's Avatar
Yeah that is the procedure except for a Porsche. However the real question I have is that besides the rubber gasket for the filter housing they provide you with a very large metal O ring. I drain my oil from the top. I have never seen a drain plug O ring that big. I just want to make sure it is not some type of additional O ring for the filter housing. I just like to make sure I have everything nailed down before I start something for the first time. In addition it would be nice to know the torque specs. since they are different from car to car.
COBB Tuning
Jan 1, 2025 09:02 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
