Sponsored By:
Sponsored By:
S8 V-10 engine seized-up
Old Mar 19, 2012 | 01:09 PM
rastarick7465's Avatar
rastarick7465 is infamous around these parts
2007 S8 with the V-10 engine siezed-up while the dealer was working on it today. Anyone know anything or ever hear of this happening before? I can't believe it. I'm crushed.
Old Mar 19, 2012 | 02:08 PM
GT3 Chuck's Avatar
Administrator
if they ran it without any oil or coolant or dropped something in the intake that would sieze it up in a hurry...whoever takes the motor apart should be able to determine the cause rather easily
Old Mar 19, 2012 | 04:13 PM
Heist's Avatar
Heist Is a GOD !Heist Is a GOD !Heist Is a GOD !Heist Is a GOD !Heist Is a GOD !Heist Is a GOD !Heist Is a GOD !Heist Is a GOD !Heist Is a GOD !Heist Is a GOD !Heist Is a GOD !
I've never heard of any Audi engine suffering from sudden seize problems.
The KO3 turbos had problems.
The 4.2 V8 had oil coking issues.
But I have never heard much about the V10s.
No one will be able to really say what happened until a complete tear down and inspection is done.
Also, I'd pop my head into the Lambo forum since the same engine was used for the Gallardo.
Old Mar 19, 2012 | 07:39 PM
djantlive's Avatar
it's the same engine as gallardo detuned. it's bullet proof. what work was being performed?
the engine is chain driven and that needs to be inspected and possibly replaced when mileage is 75k.
i would get a full analysis done by another party. the mechanic may not be honest.
Old Mar 19, 2012 | 09:21 PM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
I would get all your facts together..
Just posting in a forum that the engine seized up while getting serviced is just going to start a lot of mud slinging.
If its a dealer I would suspect that they would stand behind the work that they do and if they screwed up they will fix it.
Old Mar 19, 2012 | 09:59 PM
djantlive's Avatar
which planet are you on?
Old Mar 19, 2012 | 10:11 PM
That approach will get you far with the dealer...
Old Mar 19, 2012 | 11:08 PM
djantlive's Avatar
yea, they will only rip me off once. i am not stupid enough to go back to them.
not all dealers are crooks, not all are honest either. there are always bad apples. you just can't be too trusting.
Old Mar 20, 2012 | 08:38 AM
morpheus's Avatar
morpheus is infamous around these parts
I haven't heard of any problems with the V-10 either. However, even if it's "bulletproof" anyone know what the replacement cost is, just in case a random 50 cal hits one
Old Mar 20, 2012 | 11:06 AM
What I know so far
So I took the car in because the check engine light was on. They fixed the Intake Flap Motor and put in a fuel additive. Light was off but came back on during their test drive. Tried to fix by doing a Carbon Flush, and while doing it the engine seized up. That's what I have been told. I have not seen the engine yet.
Old Mar 20, 2012 | 11:23 AM
Heist's Avatar
Engine is probably going to run anywhere between $18-22K used, $25-30K factory fresh.
Tack on another $4,000 for installation.
In the end, it may very well make more economic sense to part out the car.
That's the part that scares me about premium cars that use parts from an exotic. When something goes "boom" it costs just as much as an exotic to fix. You get all the pain without any of the pleasure of owning one.
Old Mar 20, 2012 | 01:55 PM
thebishman's Avatar
thebishman is a splendid one to beholdthebishman is a splendid one to beholdthebishman is a splendid one to beholdthebishman is a splendid one to beholdthebishman is a splendid one to beholdthebishman is a splendid one to behold
If all you had was a CEL and the engine siezed whilst under their 'care', they should be liable for any damage imho.
Bish
Old Mar 20, 2012 | 02:08 PM
djantlive's Avatar
I think the shop should be able to fix/rebuilt the engine. They won't pay you a new or used engine but they can repair it at their cost. The next step is to remove the top of the engine. Something must have gone wrong there.
Old Mar 20, 2012 | 04:09 PM
Heist's Avatar
Bish
Yes and no. There could have been a legitimate manufacturer or part defect.
The owner could have rev damaged the engine previously or made modifications.
There is more to be determined before blame and ultimately responsibility is assigned.
Old Mar 21, 2012 | 12:29 PM
gaspasser19's Avatar
gaspasser19 is infamous around these parts
Pretty hard to "rev damage" an automatic with as many limiters as an S8 has.
Jul 29, 2019 11:13 AM
vr6tee
Aug 29, 2015 03:52 AM
The Oss
Aug 24, 2015 08:19 PM
Glasig
Aug 23, 2015 03:35 PM
