Sponsored By:
Sponsored By:
HELP need a TT RS front rotor solution !!!!
Old Jul 17, 2012 | 09:25 PM
HarrisonRuffin's Avatar
HarrisonRuffin is infamous around these parts
Are there aftermarket blades for the ttrs that direct more air, perhaps by extending a little lower than stock with a slight forward curve, maybe at home solution, piece of abs plastic attached to stock blade to reach down into undercar air flow. Would this have an bad affect on underside aerodynamics at speed?
Old Jul 28, 2012 | 07:05 PM
sabrinadaisy's Avatar
sabrinadaisy is infamous around these parts
LOBA is much reliable name, worth waiting for a few days.
Old Aug 2, 2012 | 07:04 AM
GMP Performance's Avatar
Site Sponsor
Brembos dude. http://www.racetechnologies.com/prod...012_Audi_TTS8J
and switch to carbotech brake pads. You will go through pads but your brake discs will last. They designed their track pads to be a little softer so when you braking your going through your pads and not your brake discs. Pads are much cheaper and easier to replace than brake discs.
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Just Cruise
Aug 25, 2015 12:39 PM
