Sponsored By:
Sponsored By:
B9 RS4/RS5 Intake System From APR: Big power. Low lower price!
Old Feb 5, 2025 | 07:52 AM
Nick@APR's Avatar
Nick@APR is infamous around these parts
Introducing the APR Full Intake System for the Audi RS4 and RS5 (B9) 2.9T EA839
Product Page
APR is proud to unveil the Full Intake System for the Audi RS4 and RS5 (B9) 2.9T EA839—an all-in-one solution designed to deliver maximum airflow, enhanced turbocharger efficiency, and real, measurable performance gains.
The APR Full Intake System is perfect for Audi enthusiasts seeking the ultimate intake upgrade. Unlike others that address only a portion of the intake system, requiring the inlets and outlets to neck down to the factory diameter for compatibility, this comprehensive solution replaces every component from the inlet scoop to the turbocharger inlet. This eliminates restrictions throughout the system, ensuring unmatched airflow and turbo performance with the largest inlet physically possible.
Key to the system’s superior performance is its optimized design. Making the inlet as large as possible is the goal but space is extremely limited. By maximizing the internal diameter with thin-walled heat-resistant composite materials, APR achieves an impressive 31% more airflow compared to stock. This translates directly into improved turbocharger efficiency, faster spool times, and significant power gains, adding +19 AWHP and +17 AWFT-LBS of torque on our APR Stage 1 (93) equipped RS5.
Additionally, the APR Full Intake System is engineered with functionality, performance, and sound in mind. The PEX airbox shields the filter from the engine bay, while its thoughtfully placed cutouts provide additional airflow and a refined engine sound. A massive 7” x 7” washable pleated cotton gauze filter further enhances performance with vast filtration surface area while ensuring long-lasting usability.
Whether you’re focused on unlocking power, enhancing turbo performance, or future-proofing your vehicle for upgrades, the APR Full Intake System is the only intake you’ll ever need.
Testing Results That Speak for Themselves
The performance of the factory intake system is no match for the APR Full Intake System. The stock setup is limited to a maximum flow of 484 CFM at 28” H2O, whereas our full intake system achieves a significant 36% improvement, flowing 658 CFM under the same conditions.
This increase in airflow is paired with a dramatic reduction in pressure drop across the system, allowing the turbocharger to spool faster and operate in a more efficient range of its compressor map. The result is not just theoretical—it’s power you can feel.
On our Stage 1 (93) tuned Audi RS5, simply installing the APR Full Intake System delivered an additional +19 AWHP and +17 AWFT-LBS of torque, proving its capability to unlock your vehicle’s full potential.
Product Page
Features:
  • Complete System Replacement: Includes inlet scoop, airbox, filter, and turbo inlet pipe, eliminating all factory restrictions.
  • +19 AWHP & +17 AWFT-LBS Power Gains: Measured on our APR Stage 1 (93) RS5.
  • 36% More Airflow: Improved from 484 CFM (stock) to 658 CFM.
  • Enhanced Turbocharger Efficiency: Reduces pressure drop, allowing the turbo to spool faster and operate more efficiently.
  • High-Temperature Composite Turbo Inlet: Enables thin-wall tubing for maximum internal diameter and airflow.
  • PEX Airbox: Heat-shield design with additional flow paths in low temperature zones.
  • Massive Washable Filter: 7” x 7” pleated cotton gauze with a 5.5” frontal inlet and 4” outlet for superior filtration and performance.
  • Future-Proof Design: Billet turbo inlet adapter accommodates larger turbos with a simple swap.
  • All-Inclusive Kit: Includes OEM gaskets, clamps, and hardware for an easy, bolt-on installation.
  • Emissions-Friendly: Requires no tuning and is compliant with emissions standards.
  • Improved Engine Sound: Adds a sporty, refined tone without being overbearing.
Product Page
GMP Performance
Audi Vendor Classifieds
Jun 29, 2017 03:41 PM
GMP Performance
VW
Apr 30, 2015 08:41 AM
GMP Performance
Jan 8, 2014 12:55 PM
AMS
997 Turbo Vendor Classifieds
23
Dec 2, 2013 10:06 AM
