1963 Chevy Bel Air V8
Year: 1963
Make: Chevrolet
Model: Bel Air
Price: $27200
Mileage: 65000
Color: Azure Aqua
Location (State): MI
Transmission: Automatic
Drivetrain: Rear Wheel Drive
• Rebuilt original number matching 283 V8. Cylinder heads completely reconditioned including valve seats. New rod, main & cam bearings, new oil pump & timing set, new camshaft, aluminum intake manifold. Repainted engine & related components (Joe Gibbs/DRIVEN oil)
• ARP stainless steel engine fastener kit
• Original exhaust manifolds coated to OEM finish
• New exhaust crossover pipe
• Ride Tech digital air ride system
• 700R4 transmission conversion w/custom driveshaft
• F.A.S.T. EZ-EFI fuel injection & fuel system
• F.A.S.T. 700R4 transmission kit & TV cable
• MSD HEI billet ignition distributor & MSD 6A ignition box
• Aeromotive Phantom fuel pump system
• Auto Meter electric triple gauge set (tachometer, oil psi, water temp)
• Rebuilt rear axle & new pan hard bar (2013)
• New fuel tank
• New rear brake lines
• Urethane driveshaft bushing
• EVANS waterless coolant
• New main engine wiring harness
• New OEM radiator
• New alternator & regulator
• New brake cylinders & fluid (2013)
• Chromed 15” wheels with bullet spider caps
• Diamond Back custom triple whitewall tires (2013)
• POR-15 coating on front frame section
• Sealed beam low-beam headlamp conversion with HID lighting
• LED tail lamp conversion
• LED signal lamp and license plate illumination
• New OEM carpet (May 2014)
• New OEM rubber floor mats
*All repair & replacement performed January/March 2014 unless otherwise noted.
WheelB
American Muscle
Sep 11, 2015 09:49 AM
